HTX PCI
- schmidtmotorworks
- Thank you received: 6
07 Jul 2011 16:50 #11231
by schmidtmotorworks
HTX PCI was created by schmidtmotorworks
While searching for low latency motherboards I ran across a white paper about a type of PCI called HTX that is geared toward low latency.
Does anyone know if this would be compatible with Mesa cards?
www.hypertransport.org/docs/uploads/HTX_White_Paper.pdf
- Online
- Thank you received: 5195
07 Jul 2011 18:50 #11234
Replied by PCW on topic Re:HTX PCI
These are not PCI but rather HyperTransport cards.
These have sub 5 nS latencies which are important
for high performance processing clusters or co-processors but
basically of no advantage for motion control and they have a big disadvantage:
Motherboards with HTX slots are pretty darned rare (and likely AMD only).
The sub microsecond latency of PCI/PCIE is fine for motion control
Time to create page: 0.058 seconds
