GIGABYTE GA-D525TUD Intel Atom D525 NM10 Motherboa
15 Jul 2011 08:37 #11543 by aike
Hi!
What anybody can say about this motherboard?
cgi.ebay.com/GIGABYTE-GA-D525TUD-Intel-A...&hash=item2eb602062e
I want to stay it in lathe. The lathe will be in warehouse, 2 shift, 16hours, 5 day in week.
Working temperature till 30 degree up zero (Celsium)
15 Jul 2011 11:57 #11547 by BigJohnT
98.7% feedback is horrible, I don't know anything about the motherboard.
I've just ordered a BOXD525MWV from NewEgg for $85 to test beside my D510MO.
www.newegg.com/Product/Product.aspx?Item=N82E16813121442
The BOXD525MWV does use 204 pin memory, so normal desktop memory won't work.
15 Jul 2011 13:20 #11550 by aike
I need IDE intreface for IDE-CF card adapter.
In your motherboard only SATA.
15 Jul 2011 13:52 #11552 by BigJohnT
There is quite a bit of feedback on NewEgg on that one.
www.newegg.com/Product/Product.aspx?Item...IGABYTE%20GA-D525TUD
16 Jul 2011 21:25 #11572 by paul11
aike,
I use a ga-d525tud, I use it for the same reason you are considering it. It uses a 20 pin psu plug and has ide which allowed me to use an old psu and hard drive, in the bios you can dissable one core and hyperthreading and the max jitter is around 7000, a bit lower. The sound doesn't work in ubuntu but that's not used anyway. I think the board John is using might be better but I've had no trouble with mine and got to use my old stuff.
Hope this helps, Paul11
16 Jul 2011 23:02 #11573 by aike
paul11 wrote:
aike,
Thank you, will buy this board :)
Time to create page: 0.133 seconds
