Foxcon D525 barebones
- BigJohnT
- Thank you received: 1175
01 Nov 2011 13:15 #14485
by BigJohnT
Foxcon D525 barebones was created by BigJohnT
Just a heads up the Foxcon D525 barebones system is in a 1/2 height case and a standard PCI card won't fit with the lid on... otherwise it works fine with the bonnet up.
- tenaja
- Thank you received: 5
07 Nov 2011 14:42 - 07 Nov 2011 14:45 #14637
by tenaja
Replied by tenaja on topic Re:Foxcon D525 barebones
John, just out of curiosity, what PCI card would you put in it? Anything other than an (optional) Mesa card?
For a simple system, isn't the PCI card unnecessary?
Thanks.
Thanks.
Last edit: 07 Nov 2011 14:45 by tenaja.
- BigJohnT
07 Nov 2011 18:11 #14656
by BigJohnT
Replied by BigJohnT on topic Re:Foxcon D525 barebones
This application was using a 5i20 so it would not fit when the Foxcon showed up... I'm just giving a bit of a heads up if you plan on using a full height PCI card and are eying the Foxcon.
Time to create page: 0.143 seconds
