Tiger Direct Barebones
- rfhowell68
- Harry_Y
I just rolled one up around the Atom D525 MB and it look like a good board
I spent $243 on the MB, Case, 4gb of memory, 80 GB HB, and DVD reader
(bought the hardware through Newegg)
- Thank you received: 4966
FWIW you can use 1GB or memory and 8GB of drive space and still have plenty of space. That's the spec of the machine I use for EMC2 development. The spec for running EMC2 could possibly be lower.I spent $243 on the MB, Case, 4gb of memory, 80 GB HB, and DVD reader
- BigJohnT
- Thank you received: 1175
- Harry_Y
Oh I know but at $10 for 2 gb
and the smallest sata drive being 80
I figure it was best to just put in in there to start with
- Harry_Y
So, that's like 3 tanks of gas for a CNC control computer... pretty good.
Yea The price was right
I am using an SSD which plugs directly into the SATA port, I can't afford 80GB of SSD, but $20 for 8GB was fine, and is enough for a CNC controller.
That means I have a controller with no moving parts (which is a bit peculiar, as it is rather hard to tell if it is on or off)
- Harry_Y
Where did you get that?
eBay.Where did you get that?
www.ebay.com/itm/MLC-Flash-DOM-Disk-Modu...Memory-/110671949593
- Harry_Y
Nice, I may need to use one of those for the HD
it would cure vibration concerns for a regular HD.
