AMD Ontario Fusion boards.
02 Dec 2011 22:46 - 02 Dec 2011 23:02 #15299 by wizard69
AMD Ontario Fusion boards. was created by wizard69
Hi folks:
This is a question focused on embedded boards built with AMD Ontario Fusion chips. Has anyone successfully employed any of these boards in an EMC installation? There is a stream of these boards bing introduced and frankly the better GPU technology is a draw. One I'm looking at is here: www.avalue.com.tw/products/ECM-A50M.cfm The board directly supports 8 digital in and 8 digital outs. This should be enough, or at least i'm hoping it is for a 3 axis machine
I realize that ATOM boards are often mentioned on the forum but I'm just looking for as much performance as I can get in a low power board.
Dave
Last edit: 02 Dec 2011 23:02 by andypugh. Reason: took the full stop out of the URL
02 Dec 2011 23:03 #15302 by andypugh
Replied by andypugh on topic Re:AMD Ontario Fusion boards.
That does look interesting.
You would need a driver for the onboard DIO, but that is probably half an hour's work.
03 Dec 2011 07:07 #15318 by wizard69
Replied by wizard69 on topic Re:AMD Ontario Fusion boards.
Looks interesting but I'm finding their web site to be very frustrating. Getting info/specs is a pain.
Time to create page: 0.093 seconds
