I found cheap Parallel port card that works
- Harry_Y
06 Dec 2011 23:30 #15431
by Harry_Y
I found cheap Parallel port card that works was created by Harry_Y
I took a gamble and ordered up this card for 9.99 from Newegg
www.newegg.com/Product/Product.aspx?Item=N82E16815166005
Rosewill Single Parallel (SPP/PS2/EPP/ECP)
Universal Low-Profile PCI card Model RC-302
I installed it today and tried it out, it seemed to work well in my setup.
Just passing this info along for others that may be looking for one.
- ArcEye
- Thank you received: 758
07 Dec 2011 08:50 #15437
by ArcEye
Replied by ArcEye on topic Re:I found cheap Parallel port card that works
Hi
It is a MOSCHIP MCS9805CV chipset.
Have you got it configured as input or just output?
It is quite an old chipset and it is the 9805 - 9815 chips, that people seem to have a lot of problems configuring as input.
- Harry_Y
07 Dec 2011 13:46 #15440
by Harry_Y
Replied by Harry_Y on topic Re:I found cheap Parallel port card that works
I have it set as output, and it seemed to function properly.
I actually looked for that chipset because in the Manual,
(or wiki) it talked about that one so I figured it would work.
I have a small Sherline Lathe and a Mill so for ease I setup
one LPT port for the lathe and the other one for the mill,
I am still in the tweaking process and getting it all setup
for my needs, but figured for 9.99 it was worth trying it.
Is there a better chip set I should be looking for?
Thank you
Thank you
- ArcEye
07 Dec 2011 14:13 #15442
by ArcEye
The best chipset is the one that works on your computer! It really can be that variable.
The 9815 and presumably the 9805 before it, had a firmware error which prevented them getting into proper EPP mode from what I remember, but that is only relevant if running Mesa IO cards etc.
I got a 9815 working as input a very long time ago after much effort and more recently have used 9845 and 9865 chipset cards which worked first time in input mode.
You only need a certain number of output pins, so most people fit a PCI parport board to give extra inputs for limits, encoders etc. etc. which is why the ability to use it that way becomes important.
A scan through the posts will show you how many people have had problems getting various boards to work as input.
- Harry_Y
07 Dec 2011 14:26 #15443
by Harry_Y
Thank you
The more I delve into this is the more I realize I have to learn,
so I appreciate all the help and guidance everyone is giving me.
I can only hope to help others someday.
- Harry_Y
07 Dec 2011 17:25 #15448
by Harry_Y
Here is a two port card for 13.99 that looks like it uses the Moschip MCS9865 chipset
www.newegg.com/Product/Product.aspx?Item=N82E16815124066
