Computer cases with space for EMC2 cards
- Thank you received: 4968
If you are in Germany you might be interested in
www.mesanet.eu, and www.cnc-ready.at
(though cnc-ready seems to not work right now)
- wizard69
sgs wrote:
You can mount just about anything you want in a rack mountable case. This assumes buying a case of proper size.Thanks for your response.
Is it also possible to mount the MESA cards in a normal 19-inch Rackmount Chassis ?
Yeah I'm not please with Mesa's web site nor the documentation there. What you will find is that some Manuals do hae dimensions for board mounting while others don't. So you need too download every manual to find out which manual has info and which doesn't.I think a 1U (maybe even 0,5U) or a 2U should leave plenty of space when using only a mini-ITX board in it.
For example something like this: www.idotpc.com/TheStore/pc/viewCategories.asp?idCategory=148
Mesa unfortunately doesn't supply any information how to mount their hardware anywhere, you can just see the mounting holes on the pictures (but not dimensions)
This is the world of industrial electronics. Your only option would be to go with a system built with a backplane technology like VME or one of the newer busses. This is not a cheap approach.It seems that there is not really hardware available that allows mounting all the hardware without having to modify the case / chassis manually?
Best regards.
The common approach when building industrial control panels is to bolt components to a panel plate that will reside in a panel box or mount them on a DIN rail. Yes this takes a bit of time.
