Linux, emc2, and VirtualBox
- mickelsen
24 Jan 2010 11:59 #1617
by mickelsen
Linux, emc2, and VirtualBox was created by mickelsen
Does anyone know is VirtualBox will run under the Ubuntu kernel that has been modified for Emc2?
Mark
Mark
- micges
- Thank you received: 3
24 Jan 2010 19:54 #1624
by micges
Replied by micges on topic Re:Linux, emc2, and VirtualBox
It will run.
regards,
Michael
regards,
Michael
- Anima
18 Dec 2010 20:42 #6149
by Anima
Replied by Anima on topic Re:Linux, emc2, and VirtualBox
Hi
Does EMC run well under virtualbox? - looking to use it under Fedora? - the machine is an i3 with 2 gb ram. I hope it can be used to run a CNC.
- BigJohnT
- Thank you received: 1176
19 Dec 2010 13:29 #6158
by BigJohnT
Replied by BigJohnT on topic Re:Linux, emc2, and VirtualBox
You can't run a CNC in a virtual box of any kind only the sim.
- doug6949
27 May 2011 00:30 #10106
by doug6949
Replied by doug6949 on topic Re:Linux, emc2, and VirtualBox
Hi all, blatant newbie here.
I installed the current linux/emc2 on a new computer last night - no problems.
Just now tried to install VirtualBox 4.0.8 and it tells me .....
Error: Wrong architecture 'amd64'
I'm new to linux but the cpu is definitely amd64. Am I missing something? Could the latest VB have an issue with the real time kernal? Maybe try an older version of VirtualBox?
Tnx;
Doug
Tnx;
Doug
- cncbasher
- Thank you received: 288
27 May 2011 06:56 #10109
by cncbasher
Replied by cncbasher on topic Re:Linux, emc2, and VirtualBox
realtime Kernal will not run in a Virtual box , or under any emulated or simulated enviroment , it needs direct access
- doug6949
27 May 2011 13:49 #10113
by doug6949
I'm not trying to run linux in a virtual box. The machine is set up with linux as the base OS.
I need the ability to run XP in a virtual box for programs that are not available for linux.
- Thank you received: 4968
27 May 2011 23:27 #10118
Replied by andypugh on topic Re:Linux, emc2, and VirtualBox
I have not used VirtualBox, but is there an option that allows it to declare itself to the guest OS as a range of CPUs?
As I understand it VB hides the base OS from the guest OS, which thinks it has native access to the CPU. So, the AMD64 detection is more likely to be in VB than in Ubuntu.
Time to create page: 0.167 seconds
