ASUS M2A74-AM Latency Times
- NICKKINSMAN
03 Feb 2012 02:13 #17353
by NICKKINSMAN
ASUS M2A74-AM Latency Times was created by NICKKINSMAN
I am getting high latency times (2 to 3million micro seconds) whenever the Asus machine hits the hard drive (HDD). Thought it was the HDD, but swapped out to a Dell GX280 machine and latency was fine (so guess that's not it!) Swapped the dell's original drive and still get the latency.
It comes up whenever you open a file folder, run a program, etc. If I just move windows around or don't do much of anythign, the latency stays low. I've reviewed the latency recommendations posted, but don't see any obvious settings which would affect this.
I am running servo system, and it seems to run CNC, just with the RTAI warning on startup (becuase it hits the hard drive!) Never see it otherwise.
Wanted to see if anyone else has seen this problem and there were any obvoius fixes or setting which would get it reasonable.
I think it does have a dual core, so was going to try the dual core setting thing to isolate for RTAI, but not sure that seems like the solution.
Thanks!
Nick
Thanks!
Nick
- ArcEye
- Thank you received: 758
03 Feb 2012 09:06 #17357
by ArcEye
Replied by ArcEye on topic Re:ASUS M2A74-AM Latency Times
Hi
You don't say what type of HDD this is, so am guessing SATA
I normally rate ASUS very highly, but there are quite a few references to problems with this board's SATA.
It appears that ASUS have recognised a problem, because they have issued this FAQ.
support.asus.com/FAQ/detail.aspx?SLangua...1B-ADF3-6F203E22108E
The symptoms listed in the 'Question' mirror those found on other forums etc. and include
"Operating system may hang while large disk access operations are under progress" which gets pretty close to your problem.
Hope something in there helps
I think we have had a report of HDD accesses causing problems, but that was IDE and I think eventually put down to a duff chip as could not be replicated off the MB
- Rick G
- Thank you received: 155
03 Feb 2012 11:32 #17358
by Rick G
Depending on the warning you are speaking of it may only appear one time per session regardless of how many times it occurs.
Rick G
Replied by Rick G on topic Re:ASUS M2A74-AM Latency Times
Rick G
- NICKKINSMAN
03 Feb 2012 18:53 #17365
by NICKKINSMAN
Replied by NICKKINSMAN on topic HDD type
I do have a SATA drive, should have mentioned it. I will check that out and see if anything can work.
Time to create page: 0.120 seconds
