Elite Group 651-M (V1.0) motherboard software CD
- Graham Symns
12 Apr 2012 22:15 #19161
by Graham Symns
Replied by Graham Symns on topic Re:Elite Group 651-M (V1.0) motherboard software CD
Hi ArcEye,
Yes I have loaded 8.04 to the 4.3 Gbyte HDD and in this situation I am un-able to load the G-Code Reference.
I tried to set the browser using the GUI..It already had Firefox selected and the command (greyed out) was
"firefox %s"
I still was not able to get the G-Code Reference to load.
I went to "Howto Geek....." but could not do any better.
He quotes using the command line process as an alternative but I did not see any way to do that.
I take your advice re the 80 Gbyte HDD...it will come in handy at some stage.
Regards Graham
"firefox %s"
Regards Graham
- ArcEye
- Thank you received: 758
13 Apr 2012 08:09 - 13 Apr 2012 08:29 #19163
by ArcEye
Replied by ArcEye on topic Re:Elite Group 651-M (V1.0) motherboard software CD
Hi
I have never used the quick ref to G Codes, not sure it continued beyond 2.4.3
Open a terminal and type
$: sudo update-alternatives --config x-www-browser
You then get
There are 2 choices for the alternative x-www-browser (providing /usr/bin/x-www-browser).
Selection Path Priority Status
* 0 /usr/bin/konqueror 100 auto mode
1 /usr/bin/firefox 40 manual mode
2 /usr/bin/konqueror 100 manual mode
Press enter to keep the current choice[*], or type selection number:
enter
$: 1 (or whatever is right one if choices different)
reply is
update-alternatives: using /usr/bin/firefox to provide /usr/bin/x-www-browser (x-www-browser) in manual mode.
I have just done this and it works fine.
The default browser is Konqueror, but unless you have installed KDE it does not get installed.
If that does not work still just create bookmarks in your browser to the documentation you want.
Unfortunately there is a typo in the example -config should be --config.I went to "Howto Geek....." but could not do any better.
You then get
enter
reply is
Last edit: 13 Apr 2012 08:29 by ArcEye.
- BigJohnT
- Thank you received: 1175
13 Apr 2012 12:21 #19170
by BigJohnT
Replied by BigJohnT on topic Re:Elite Group 651-M (V1.0) motherboard software CD
The same G code reference is in the User Manual.
- Graham Symns
13 Apr 2012 21:13 #19179
by Graham Symns
Hi BigJohnT,
Thanks for your reply.
I take on board your advice.
I tend to be like a dog with a bone so your help is appreciated.
Hi ArcEye,
I re-read Howto Geek and read what some respondents had said ,before BigJohnT replied,and then the penny dropped regarding the double
hyphen.The result however was less than useful.It gave the following:
"There is only 1 program which provides x-www-browser
"/usr/bin/firefox). Nothing to configure."
So I guess I'll carry on using the EMC2 User Manual
So thanks again
Regards Graham
Hi ArcEye,
So thanks again
Regards Graham
Time to create page: 0.799 seconds
