USB Wifi - Airlink 101 AWLL5088
- tmade
27 Apr 2012 17:48 #19591
by tmade
USB Wifi - Airlink 101 AWLL5088 was created by tmade
If this has been covered somewhere else that I haven't found, just link me.
I have a new Intel D525MW board, and I was going to use the Airlink 5088 Wifi-N USB adapter to connect to my wifi network. The adapter works quite well with the base 10.04 install (instructions here here ). However when I run the install script for 10.04 to install LinuxCNC, it breaks this, and it can't be installed.
The actual error I get is
I assume this is broken because of the realtime kernel change, but is there anyway to fix it? If not, do you have a good wifi USB suggestion?
Thanks!
make ARCH=i386 CROSS_COMPILE= -C /lib/modules/2.6.32-122-rtai/build M=/usr/src/RTL8188C_8192C_8192D_USB_linux_v3.3.2_3192.20120103/driver/rtl8188C_8192C_8192D_usb_linux_v3.3.2_3192.20120103 modules
make: *** /lib/modules/2.6.32-122-rtai/build: No such file or directory. Stop.
make: *** [modules] Error 2
Compile make driver error: 2
Please check error Mesg
Thanks!
- Thank you received: 4967
27 Apr 2012 21:33 #19596
Replied by andypugh on topic Re:USB Wifi - Airlink 101 AWLL5088
tmade wrote:
I am sure that there is a way.
However, I gave up and used a a router in WDS mode and a wired connection from that to the PC.
www.amazon.com/Tenda-Wireless-N-Router-8...id=1335562031&sr=8-2
- ArcEye
- Thank you received: 758
28 Apr 2012 11:46 - 28 Apr 2012 11:57 #19607
by ArcEye
Replied by ArcEye on topic Re:USB Wifi - Airlink 101 AWLL5088
Hi
There seems to be a problem with the RealTek site, I can't download the RTL8188CUS_v2.0.1324.zip
(Cancel that - just managed to get Ver 3.3.2_3192 which is what is now listed on the RealTek site for this kernel.)
I have had to compile a lot of RealTek stuff before and it usually works.
I'll have a look.
I'll have a look.
Last edit: 28 Apr 2012 11:57 by ArcEye.
- ArcEye
28 Apr 2012 12:12 #19608
by ArcEye
Hi
Attached is the module I compiled, the driver seems to cover the range from 8188 - 8192CU
See if that works, if not you will have to install the files for a development environment, I think that was all the error was complaining about, you don't have kernel headers etc.
- ArcEye
28 Apr 2012 13:57 - 28 Apr 2012 15:35 #19611
by ArcEye
A bit of explanation probably required.
When I say
Unzip the module into a directory
From that directory run in a terminal
sudo install -p -m 644 8192cu.ko /lib/modules/2.6.32-122-rtai/kernel/drivers/net/wireless/
then
sudo /sbin/depmod -a 2.6.32-122-rtai
Then you should be able to run
sudo modprobe 8192cu to load it
cat /proc/modules will show it listed as loaded
sudo rmmod 8192cu will unload it
Beyond that you need to do whatever is required to use it with your adapter / card
May be nothing more than enter the line 8192cu into /etc/modules so that it is loaded at boot time, but follow whatever instructions you have for that.
When I say
what I mean is.See if that works
then
Last edit: 28 Apr 2012 15:35 by ArcEye.
- tmade
28 Apr 2012 16:49 #19613
by tmade
Replied by tmade on topic Re:USB Wifi - Airlink 101 AWLL5088
Thanks for that. I'll give it a try when I get back to the computer tomorrow or Monday and post back here if it succeeded or failed.
Also, yea, the new Realtek driver is the one I was using. The Ubuntu compatible hardware list is defunct now - only a seal of approval I think.
Time to create page: 0.065 seconds
