Adding a numeric keypad.
10 May 2012 08:33 #19961 by grey1beard
Adding a numeric keypad. was created by grey1beard
As my keyboard is mounted on the wall behind the -X axis end, jogging into the middle of the x axis leaves me at arm's length, trying to see the tool piece !
It only occurred to me yesterday that a usb keypad might give me the "arm" extension I need, and perhaps I could even map an E stop to one of the keys ?
Is it this simple ?
10 May 2012 09:49 #19967 by ArcEye
Replied by ArcEye on topic Re:Adding a numeric keypad.
Hi
See www.linuxcnc.org/index.php/english/compo...=21&id=14675&limit=6
for a long discussion about key mapping
As for the keypad itself, so long as it is detected OK it just inputs the same codes as your keyboard so should not be a problem.
10 May 2012 09:57 #19969 by grey1beard
Replied by grey1beard on topic Re:Adding a numeric keypad.
Hi Alex, and thanks.
Yes, I've been reading the link you gave me already this morning, and have my own machine in a similar position to the OP.
Taken me a little while to find a pad that actually says it is compatible with Linux, but having identified one, I'll give it a go.
As I get older, my arms seem to be getting shorter ;)
Regards
10 May 2012 13:23 - 10 May 2012 16:06 #19973 by ArcEye
Hi
You should find that you can plug in second USB keyboard and it will be detected and you can use either/both keyboards.
Same applies to a restricted keyboard ie numberpad
Very few manufacturers say their products work with Linux, because they know nothing about it.
Normally you just want one that doesn't need drivers, because a generic device like this shouldn't even for Windoze.
If you plug in whilst running tail -f /var/log/messages in a terminal, you can see if the device is recognised.
This is what I got when I plugged in a 2nd keyboard to this computer
May 10 14:01:20 INTEL-QUAD kernel: [ 1099.444019] usb 7-1: new low speed USB device using uhci_hcd and address 2
May 10 14:01:20 INTEL-QUAD kernel: [ 1099.620173] usb 7-1: configuration #1 chosen from 1 choice
May 10 14:01:20 INTEL-QUAD kernel: [ 1099.638462] input: CHESEN USB Keyboard as /devices/pci0000:00/0000:00:1d.1/usb7/7-1/7-1:1.0/input/input14
May 10 14:01:20 INTEL-QUAD kernel: [ 1099.638558] generic-usb 0003:0A81:0101.0004: input,hidraw3: USB HID v1.10 Keyboard [CHESEN USB Keyboard] on usb-0000:00:1d.1-1/input0
May 10 14:01:20 INTEL-QUAD kernel: [ 1099.668155] input: CHESEN USB Keyboard as /devices/pci0000:00/0000:00:1d.1/usb7/7-1/7-1:1.1/input/input15
May 10 14:01:20 INTEL-QUAD kernel: [ 1099.668274] generic-usb 0003:0A81:0101.0005: input,hidraw4: USB HID v1.10 Device [CHESEN USB Keyboard] on usb-0000:00:1d.1-1/input1
PS
Alex Joni's name is on all the email notifications, he set up the system.
Last edit: 10 May 2012 16:06 by ArcEye.
10 May 2012 17:21 #19986 by grey1beard
:blush:
Thanks ArcEye.
Key pad ordered, so I hope I'll be less stretched soon.
Time to create page: 0.058 seconds
