- Thank you received: 5334
EMC2 running on Raspberry Pi?
7 years 5 months ago #134286
Replied by PCW on topic EMC2 running on Raspberry Pi?
LinuxCNC 2.8
7 years 5 months ago #134305
Replied by tommylight on topic EMC2 running on Raspberry Pi?
Might call you on that soon to do some testing.
Thnx.
Tom.
Thnx.
Tom.
7 years 5 months ago #134312
by jmr
Replied by jmr on topic EMC2 running on Raspberry Pi?
I started with this:
unofficialpi.org/Distros/RealtimePi/
and got it working, it did not go with stock /boot/cmdline.txt. Now I'm trying to satisfy the dependencies... MAN that thing is SLOW. Maybe my sd card sucks, but this thing is still seriously slower than pentium2 with very old ide disk. But once it can run hal it may be useful.
@PCW: Is the version 3 good enough with opengl to run its own axis display? Well, those RPI "shields" look a lot like a problem solver, I'm quite interested.
7 years 5 months ago #134318
OpenGL is not bad _IF_ you enable hardware OpenGL support, software OpenGL is hopeless...
Speed on my RPI3 is a bit slower than a Atom D525 but not unacceptable.
7 years 5 months ago #134327
by viktan
Replied by viktan on topic EMC2 running on Raspberry Pi?
Here is performance of raspi3 with HW OpenGL, machinekit and bigger g-code:
I will try install also linuxcnc
The following user(s) said Thank You: jmr
- Mike_Eitel
- Thank you received: 183
7 years 5 months ago #134329
by Mike_Eitel
Replied by Mike_Eitel on topic EMC2 running on Raspberry Pi?
I have good results speeding rpi3 by using ssd. Finding a reliable USB to ssd took much longer than expected but finally I came to:
de.aliexpress.com/item/X800-2-5-inch-SAT...l-B/32791789269.html
Speeds up a lot and until now could handle all ssds I tried.
Mike
Mike
Time to create page: 0.297 seconds
