PC hardware to run LinxCNC
- AlexN
Thanks for the links and advice. I've just spent some time looking around the MiniBox site - I hadn't come across them until your post. I had found a Siverstone SFX 450W psu over the weekend, but the Picos look really interesting, especially their exceedingly small footprints (other than that they appear to use a wall-wart), and ultra-lower power use, of course.
I have in fact been trawling the rsaustralia web a lot over the last week - lots of useful stuff there. I've acquired quite a number of milling cutters amongst other things from them in the past; more stock and better quality than Jaycar - and more expensive
Cheers,
Alex.
- jmelson
- Thank you received: 160
AlexN wrote:
Finding the Atom board is a bit tricky here too as production appears to have been halted ("due to lack of demand"
In the US, Logic Supply, NewEgg and Directron all show the Intel D525MW boxed motherboard
in stock. I have not found any reference to it going out of production.
The D510MO has gone out of production, it was superseded by the D525 chip set.
Jon
- AlexN
That and the "no longer available" descriptions on a number of Oz web sites led me to leap instantly to the wrong conclusion - a bad habit of mine.
- gera229
How much did you spend for all your components?
- AlexN
Hi gera229,Let me know how the D525 goes.
Do you mean the PC parts or the control box/ steepers, or the whole box and dice including the mill. Actually, the whole box and dice doesn't include the box yet
I paid AU$90 for the D525, plus another $19 for freight. I think that the latter was a bit cheeky, since i ordered the thig a week ago and still haven't got it - although they supposedly had two of the boards in stock here in Sydney when I ordered mine. I have an uneasy feeling about this...
As to the cost of all the other bits and pieces, it was about 5 years ago(!), so I'd have to find the old receipts. I couldn't even put an estimate on it at the moment. What i do remember, however, is that I got the four good-quality steppers for US$20 each, an amazing bargain since their list price is currently $US99/motor! My special bargain price could have been because I bought the mill and other stuff from the same chap.
Hope that makes some sort of sense.
Cheers,
Alex
- AlexN
SSD versus PXE boot with NFS is really a question of money vs. time. SSE is easy, but the drive costs about the same as the motherboard. PXE/NFS is more work to set up, but costs nothing if you have the server already. performance for this task is not an issue: either will just work.
In contrast to the machine controller (which must meet LinuxCNC's requirements) you can use any random computer to run as a Linux server. I personally think a gig-e interface is highly desireable, and you clearly need enough disk to support whatever services you intend it to provide.
I must confess to only learning of PXE's existence with your post, which for some odd reason I only just found
As to disk size, i'm currently leaning towards either a 32 or 64 GB ssd, as I will possibly install XP/Mach3 on it "for fun."
Alex.
- arch dude
XP and Mach3 are intrinsically evil
- AlexN
I did a bit of searching this morning and found that OS X doesn't do PXE as such, but does use bootpd. I'll attempt cross that particular bridge if I come to it, however. At the moment the power supply for the drives (I thInk I may have the wrong transformer) and finding a suitable case are taking up most of the time. RS Australia has a lot of cases that are too small or too expensive. Andy Pugh's extrusion frame looks to be a possible solution.
- Thank you received: 5013
Here is another one (I needed a 20" rack. Not a 19"…) for a 1U server PC.Andy Pugh's extrusion frame looks to be a possible solution.
picasaweb.google.com/lh/photo/QiYY_5vRG2...pFm0?feat=directlink
20x20 extrusion and MDF painted black.
(It's easy to expand and contract as needed too)
- AlexN
Hi Andy,
I've been quiet but busy
After an almos- two-week wait for something that was supposedly in stock (probably in stock in the warehouse in HK), the D525 board was picked up by the courier this arvo, so hopefully it will turn up tomorrow. As tomorrow happens to be Friday, I won't hold my breath as couriers in Sydney on Friday are - in my experience - almost totally unreliable on account of the insane Friday traffic congestion here in Sydney. As I don't have anything else to add onto the board or power it up with at the moment - I've been waiting for the board to actually show before doing that - that's probably a moot point anyway. Maybe Monday...
