USB Current 5 volts
11 Jun 2012 23:31 #20828 by cwebs
USB Current 5 volts was created by cwebs
Anyone know how much current you can safely pull of the USB 5 volts? I would like to use that to run my SSR relays and remove a 5 volt power supply that I am now using. Thanks Carl
12 Jun 2012 00:15 #20829 by PCW
Replied by PCW on topic Re:USB Current 5 volts
I think any USB host needs to supply the minimum (100 mA) and most
(except perhaps hubs) should supply the maximum (450 mA) OK
12 Jun 2012 00:32 #20830 by cwebs
Replied by cwebs on topic Re:USB Current 5 volts
Thanks PCW. That's more then I need for a couple SSRs and power on LED. Carl
Time to create page: 0.160 seconds
