Fantastic latency on Live CD, horrible on HDD
15 Jun 2012 16:01 #20961 by lukepighetti
Replied by lukepighetti on topic Re:Fantastic latency on Live CD, horrible on HDD
Just wanted to post a quick update
Been running 2 instances of glxgears at different resolutions, 3 instances of "$ while true;do /bin/true;done", and 1 instance of "$ ping google.com"
So far running it for 2 hours straight
max jitter is 9257 ns / 9854 ns
15 Jun 2012 17:06 #20965 by ArcEye
That is a pretty good loaded figure. About the same as my 2 workshop P4s which both run a 30K base thread rock solidly.
Can you post a copy of your xorg,conf file please so I can possibly use that as an example (better rename it xorg.conf.txt or similar or it won't upload).
I have a vanilla install of 10.04 on another partition, I will play with changing over to vesa driver on that and try to put together a simple method for creating the required xorg.conf.
I know already that telling people to interrupt the boot and go to a terminal session to use xorg-configure just freaks them, so will have to find an easier method for the Linux novice.
15 Jun 2012 17:15 - 15 Jun 2012 17:17 #20966 by lukepighetti
Posting this from the LinuxCNC computer while the stress test is running. Reset the statistics for laughs an hour ago and I'm still 8.5k/8.5k :P
the only lines i added
	Driver		"vesa"
	HorizSync	30-60
	VertRefresh	60-75
File Name: xorg.txt
File Size:1 KB
Last edit: 15 Jun 2012 17:17 by lukepighetti.
16 Jun 2012 09:51 #20990 by ArcEye
Hi
Thanks for the file, now I have started looking into it, a couple of questions.
Is your monitor CRT or TFT/LCD etc?
How did you arrive at the refresh rates, do you have the manual or was that what xrandr threw up for that resolution?
16 Jun 2012 11:24 #20993 by Rick G
It has been a while but I think I started here..
wiki.ubuntu.com/X/Config
This suggests that a simple solution would be to use gedit to create the file, save to proper location and then edit it to fit your needs.
also from my notes I downloaded a while ago...
In order to generate xorg.conf you need to switch to one virtual console using the key combination CTRL + ALT + F1.
Now execute the following commands:
# sudo service gdm stop
This command will stop the X.
Now we need to generate the xorg.conf file:
# sudo Xorg -configure
This has generated the file in ~/xorg.conf.new.
We need to make the X using it so we have to put this file inside /etc/X11/
# sudo mv ~/xorg.conf.new /etc/X11/xorg.conf
After moving this file to the proper location you can start the X again and see what happens:
# sudo service gdm start
Rick G
16 Jun 2012 12:53 #20996 by ArcEye
Hi Rick,
Thanks, that is pretty much all that is needed.
I couldn't find a simple Ubuntu wiki to link directly to, so will probably just use that
Telling people to interupt GRUB and edit the kernel params to force runlevel 3 etc. was never going to be a winner!
The Linuxcnc troubleshooting wiki pretty well covers things, except that it doesn't explain that you cannot use Xorg -configure when there is a running X server.
That has come up as a problem a few times on threads.
16 Jun 2012 13:19 #20997 by lukepighetti
ArcEye wrote:
Hi
My monitor is an old LCD monitor. I found the user manual online and punched in the manufacturers range. VESA seemed to pick the best one for me and it worked. I hope it works as smoothly on other systems too.
16 Jun 2012 13:19 #20998 by ArcEye
16 Jun 2012 13:53 #21001 by lukepighetti
excellent, glad my post could possibly help others in the future!
Really excited to get this thing hooked up to my stepper motors. Psyched that I finally got sub 10k latencies. Thanks again all for the help
17 Jun 2012 08:21 #21030 by Rick G
Wiki now edited to incorporate both items
Looks good ArcEye, that should help a lot of people.
Rick G
Time to create page: 0.482 seconds
