Latency spikes
- ioiotutu
19 Jul 2012 14:40 #22194
by ioiotutu
Latency spikes was created by ioiotutu
i have a P4 2,5 gb, 1gb ram chipset intel (82801EB/ER), ati radeon with linuxcnc installed.
Latency test is about 4000/6000 very good and with parallel card all work fine.
My problem is that sometimes latency goes to 240000! In this moment all stucks.
I tried to change graphic drive from "radeon" to "vesa" or "fbdev" but the problem is the same.
this happen also if i don't use keybord or mouse, random i have latency >200000.
May be SMI?
I read in the FAQ that SMI for 82801 EB/ER is not a problem.
any suggestions?
Thanks.
May be SMI?
any suggestions?
Thanks.
- ArcEye
- Thank you received: 758
19 Jul 2012 14:58 #22197
by ArcEye
Replied by ArcEye on topic Re:Latency spikes
Hi
I have the 2 P4 machines in question and there is no SMI problem with that chip I know of and there is no SMI listing in the smi code for that chip either
Try the latency test as outlined in
www.linuxcnc.org/index.php/english/compo...ew&catid=18&id=19022
This should help pinpoint when the spikes occur. SMI will normally be 32 or 64 seconds apart and very regular irrespective of whatever else is happening.
- ioiotutu
19 Jul 2012 21:29 #22226
by ioiotutu
Replied by ioiotutu on topic Re:Latency spikes
Thank,
with this tool the latency seems to be constant at 7190. Now is active fbdev driver.
I stopped many services like bluetooth.
I'll test the system in the next days.
regards.
regards.
- ArcEye
24 Jul 2012 10:18 - 24 Jul 2012 15:32 #22380
by ArcEye
Co-incidentally I bought in another of the same Fujitsu-Siemens P4 2.4GHz computers a few days ago
It has the same chipset (82801EB/ER) and I set BIOS the same way, completely disabling APM, setting the fan to max so that it doesn't keep checking temp, disabling hyper-threading etc
The video chipset is the same (Intel 82865G video chipset) so I was expecting the same figures as the other 2 I have.
When I ran a latency-test it was initially 5500 ish and then spiked to well over 200,000 as soon as I touched the mouse (that may well have been co-incidence) and kept spiking at a period of only a few seconds.
The old computer I was going to replace, runs unloaded at 5995 and even with quite brutal loading never got above 9500.
I have stripped the new one, upgraded all the peripherals on the old one and given it the new case etc. and the new computer will be doing house duty.
When I get time I will try to fathom out what is causing the spikes, which may assist.
In the interim I am tempted to remove this computer from the 'known good' list - I put it there so suppose I am entitled!
PS
Installed 8.04 and ran a latency test for 5 hours on this machine with different memory sticks, HDD, keyboard, mouse, VDU
It ran on 10,553 for 3 hours or more and then had a single spike which sent it to 29000 ish
Very strange - it is not SMI thats all I can say for now
Had it stayed on 10553 I would have been tempted to blame mismatched memory modules for the first set of figures.
PS
Last edit: 24 Jul 2012 15:32 by ArcEye.
Time to create page: 0.087 seconds
