Unexpected realtime delay
25 Jul 2012 20:58 - 26 Jul 2012 08:07 #22465 by majidkarimi
Unexpected realtime delay was created by majidkarimi
I have a problem with linuxcnc running time
I see the message Unexpected realtime delay and Unexpected realtime delay on task 1
help me please
(moved to a new post)
Last edit: 26 Jul 2012 08:07 by ArcEye. Reason: Moved
26 Jul 2012 08:14 - 26 Jul 2012 08:16 #22474 by ArcEye
Replied by ArcEye on topic Re:Unexpected realtime delay
Hi
Your error can be caused by a lot of things - SMI is about the last thing to check - so moved to a separate post.
You will need to zip your .ini and .hal files plus a print of the errors you get plus the dmesg file from /var/logs before anyone can assist properly.
First see
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
do a test and post the results
For more info re latency also see my FAQ at the head of the computer section
Last edit: 26 Jul 2012 08:16 by ArcEye.
Time to create page: 0.174 seconds
