no libaccess installed in LinuxCNC-LiveCD
02 Aug 2012 19:28 #22686 by t1m0n
I installed LinuxCNC from LiveCD (Ubuntu 10.04, 2.6.32-122-RTAI, LinuxCNC 2.5).
I load a kernel module with insmod to work in kernel space. I think it works.
Now, I try to install the driver library. It needs libpciaccess.
Both, kernel module and library are required to use a cifx card over PCI-Port.
I searched and found libpciaccess: pkgs.org/ubuntu-10.04/ubuntu-main-i386/l...11.0-1_i386.deb.html
Description for libpciaccess: Provides functionality for X to access the PCI bus and devices in a platform-independant way.
Parallel port is the standard interface for linuxcnc, right? I want to integrate sercos-iii with cifx card over PCI.
But I don't understand how the parallelport should work out-of-the-box if libpciaccess is not installed.
Is PCI not required to use the parallel port if parallel port is onboard?
Only if I want to use a card direct over pci port libpciaccess is required, right?
But what is know with HAL?
03 Aug 2012 00:01 - 03 Aug 2012 00:02 #22695 by andypugh
Replied by andypugh on topic Re:no libaccess installed in LinuxCNC-LiveCD
No, LinuxCNC has many drivers for PCI, PCIe and even ISA hardware.
We only support the parallel port because people want to use it. It's nasty.
I suspect not.
See for example: git.linuxcnc.org/gitweb?p=linuxcnc.git;a...8c0c968ad374;hb=HEAD
Which access PCI hardware with simple inb() and outb() instructions to a port address.
That is written in C, and isn't very clear. You can probably use "comp" which is a preprocessing language and allows for much smaller driver files. This one:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...2ea8c65f4e2e;hb=HEAD
Is similar to the previous one (but is for an ISA card, not a PCI card)
Last edit: 03 Aug 2012 00:02 by andypugh.
11 Aug 2012 09:57 - 12 May 2013 17:41 #23060 by t1m0n
Thanks for the link to the Code for pci_8255.c.
Last edit: 12 May 2013 17:41 by t1m0n.
Time to create page: 0.426 seconds
