netmos 9865
- lorisdag
06 Aug 2012 15:26 #22911
by lorisdag
netmos 9865 was created by lorisdag
Hello, I am installing 4 cards pci lpt chip netmos 9865 but I can not,
I'm using 2.5.0 emc2
here is the file lspci-v
02:05.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
Subsystem: Device a000:2000
Flags: bus master, medium devsel, latency 64, IRQ 11
I/O ports at ec00
I/O ports at e880
Memory at fbfff000 (32-bit, non-prefetchable) [size=4K]
Memory at fbffe000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
02:06.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
I/O ports at e800
I/O ports at e480
Memory at fbffd000 (32-bit, non-prefetchable) [size=4K]
Memory at fbffc000 (32-bit, non-prefetchable) [size=4K]
02:07.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
I/O ports at e400
I/O ports at e080
Memory at fbffb000 (32-bit, non-prefetchable) [size=4K]
Memory at fbffa000 (32-bit, non-prefetchable) [size=4K]
02:08.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
Flags: bus master, medium devsel, latency 64, IRQ 10
I/O ports at e000
I/O ports at dc00
Memory at fbff9000 (32-bit, non-prefetchable) [size=4K]
Memory at fbff8000 (32-bit, non-prefetchable) [size=4K]
I also installed the driver but do not work
help ................
I/O ports at ec00
I/O ports at e880
I/O ports at e800
I/O ports at e480
I/O ports at e400
I/O ports at e080
I/O ports at e000
I/O ports at dc00
- ArcEye
- Thank you received: 758
06 Aug 2012 15:49 - 06 Aug 2012 15:49 #22913
by ArcEye
Replied by ArcEye on topic Re:netmos 9865
Hi
See my FAQ at www.linuxcnc.org/index.php/english/compo...ew&catid=18&id=18917 for how to address them in the .hal file
Normally the first address shown is the port address with Moschip
So your ports should be at 0xe00 0xe400 0xe800 0xec00, but don't make life too complicated, just insert one card at a time, then you will know which port relates to which card
If you don't solve it, come back with a post of your main .hal file
How are you installing the cards?I am installing 4 cards pci lpt chip netmos 9865 but I can not,
There is no driver required, so don't try to load anything that came with the cards.I also installed the driver but do not work
Last edit: 06 Aug 2012 15:49 by ArcEye.
- lorisdag
07 Aug 2012 15:52 #22949
by lorisdag
Replied by lorisdag on topic Re:netmos 9865
Hello, it works fine thanks ...............
- ArcEye
07 Aug 2012 16:26 #22951
by ArcEye
Glad it helped you
- lorisdag
07 Aug 2012 17:32 #22954
by lorisdag
Hello, I configured 3 ports "out" and 1 "" I checked the pins have 3.3v 10-11-12-13-15 rather than "2-3-4-5-6-7-8-9" not. How do I configure them to have 3.3v as 10-11-12-13-15 pin for use as "in". Thanks
- ArcEye
08 Aug 2012 07:21 #22968
by ArcEye
Hi
If you configure as loadrt hal_parport cfg="0xXXXX out" the pins are allocated thus
1 in
2-9 out
10-13 in
14 out
15 in
16-17 out
If configured loadrt hal_parport cfg="0xXXXX in" pins 2-9 become in
giving you 8 more input pins
You would be best advised to put your spindle and all the axis drives on parport.0 and if you need to put all your limit switches and home switches on separate pins use parport.1 with all the extra inputs for that.
I just chain all my limits together in series so that if one activates it breaks the circuit which saves loads of pins and enables everything on one parport
1 in
2-9 out
10-13 in
14 out
15 in
16-17 out
- lorisdag
08 Aug 2012 18:33 #22978
by lorisdag
hello, but the pin 2/9 does not have power like 10/11/12/13/15 pin when configured as "in"
- ArcEye
09 Aug 2012 11:03 #22990
by ArcEye
Hi
You don't say how you are testing or when.
The parallel port is in an unknown state until Linuxcnc has loaded the parport driver and started.
The output pins will emit TTL signals, below 0.8v is OFF and 2.4 - 4.8v is ON
The inputs can sink ~5V to 25mA and use the same input TTL convention as above
What you need to do is start your configuration and the open Machine > Show Hal Configuration > pins > partport.0 (parport.1 etc)
Then check that the right pins are present and watch the pins when you apply a signal to them or send a signal from them
You can use JT's parallel port tester www.linuxcnc.org/index.php/english/compo...iew&catid=18&id=4743
or
just attach a buffered BoB and ground the input pins and watch the Hal Configuration display
Remember that an opto isolated BoB will invert the logic on inputs, so you may need to use the -not suffix on your net assignments
or
- lorisdag
10 Aug 2012 13:26 #23021
by lorisdag
Hello, everything works perfectly!!! thanks
Time to create page: 0.087 seconds
