Problem with SMI fix
- Tonico
16 Aug 2012 23:36 #23318
by Tonico
Replied by Tonico on topic Re:Problem with SMI fix
I am seeing something strange with the "new motherboard" which is an Asus A/7V333. I can run the latency test from the command line all day line no problem.
If I try to run it from the drop down menu the system sort of goes into La-La land for a while than it opens a window, nothing happens, than closes it.
If I try to run the test from the command line after that I get:
insmod: error inserting '/usr/realtime-2.6.24-16-rtai/modules/rtai_lxrt.ko': -1 Invalid module format
ERROR: cannot load /usr/realtime-2.6.24-16-rtai/modules/rtai_lxrt.ko
CANNOT CREATE MAILBOX
CANNOT FIND MAILBOX
The only way I can get it to run is by rebooting. I am fairly certain that there is a more elegant way to clear this that I don't know about. But is there a problem with the earlier version of LinuxCNC that causes this?
TIA
Tony
CANNOT FIND MAILBOX
TIA
Tony
- ArcEye
- Thank you received: 758
17 Aug 2012 08:00 - 17 Aug 2012 10:49 #23329
by ArcEye
Replied by ArcEye on topic Re:Problem with SMI fix
Hi
It sounds like the realtime system is not unloading properly for some reason after the first latency test.
What on earth the
It really does not matter, you should only need to run latency-test once properly in the lifetime of the machine, unless you change hardware (video card perhaps).
Run it for several hours as per the instructions, write down the figures and go from there
What on earth the
is about I don't know, maybe a corrupted menu.CANNOT CREATE MAILBOX
CANNOT FIND MAILBOX
Last edit: 17 Aug 2012 10:49 by ArcEye.
- Tonico
18 Aug 2012 11:34 #23381
by Tonico
It looks like that it seems to work. after almost 24 hours:
RTH| lat min| ovl min| lat avg| lat max| ovl max| overruns
RTD| -1178| -1217| 545| 8856| 19274| 0
RTD| -1188| -1217| 574| 7589| 19274| 0
RTD| -1194| -1217| 666| 7847| 19274| 0
RTD| -1194| -1217| 460| 8740| 19274| 0
RTD| -1182| -1217| 476| 8546| 19274| 0
RTD| -1171| -1217| 432| 8359| 19274| 0
RTD| -1184| -1217| 449| 8061| 19274| 0
RTD| -1200| -1217| 555| 8673| 19274| 0
RTD| -1184| -1217| 415| 9711| 19274| 0
RTD| -1191| -1217| 539| 17407| 19274| 0
RTD| -1180| -1217| 475| 7942| 19274| 0
RTD| -1183| -1217| 465| 7953| 19274| 0
RTD| -1182| -1217| 575| 7161| 19274| 0
RTD| -1176| -1217| 463| 8373| 19274| 0
RTD| -1182| -1217| 574| 8102| 19274| 0
RTD| -1190| -1217| 455| 10587| 19274| 0
RTD| -1191| -1217| 551| 8228| 19274| 0
RTD| -1191| -1217| 419| 7255| 19274| 0
RTD| -1178| -1217| 537| 9882| 19274| 0
RTD| -1193| -1217| 439| 9336| 19274| 0
RTD| -1182| -1217| 474| 7102| 19274| 0
I am using gzip -c /dev/urandom > /dev/null for a load with the CPU at 100%
I would have liked to run some videos but I am having one heck of a time to load Flash player in order to run Utube videos. It expects FireFox 4, the live CD only has Firefox 3
Thanks for all the help, I really appreciated it
Tony
Tony
- ArcEye
18 Aug 2012 15:23 #23382
by ArcEye
Hi
Those figures look very usable, now you should be able to start making some chips!
Time to create page: 0.054 seconds
