Arduino I/O with Linuxcnc
5 years 9 months ago #195193 by zz912
Replied by zz912 on topic Arduino I/O with Linuxcnc
I hope there are no problems caused by removing that line.
You do not have to worry
Singleton means that only one component can run. Otherwise, it is generally possible to load components in multiple instances.
The singleton then has no instance number in the signal name, because it is the only one possible.
So a normal component has eg serialreceive.0.bit-14,
singleton should eg serialreceive.bit-14.
Source: Mex: forum.strojirenstvi.cz/viewtopic.php?t=3...ingleton+yes#p384233
Time to create page: 0.064 seconds
