Radeon x1650Pro
- marsheng
08 Jan 2013 18:46 #28493
by marsheng
Radeon x1650Pro was created by marsheng
Hi Chaps
While I'm setting up the CNC I thought that having 2 screens would be a help. One for CNC and the other for the manuals.
I'm running a Intel 4 at 18 Ghz as the chip runs quite cool and 1 Gb ram. The system ran quite well until I added the Radeon card. Now it is incredibly slow. I'm not sure on how drivers work with which versions of software.
Any suggestions on how to get it to run faster?
Thanks Wallace
Thanks Wallace
- BigJohnT
- Thank you received: 1177
08 Jan 2013 20:19 #28495
by BigJohnT
Replied by BigJohnT on topic Radeon x1650Pro
Just a WAG on my part but did you check the CPU and memory usage to see if they are maxed out? Go to System > Administration > System Monitor to see what is going on with the CPU and memory.
- ArcEye
- Thank you received: 758
08 Jan 2013 22:14 - 08 Jan 2013 22:19 #28498
by ArcEye
Replied by ArcEye on topic Radeon x1650Pro
Hi
The board itself does not appear too bad, but there is a lot of negative comment on the drivers.
It might be worth installing the vesa driver for each head and see what happens. It has been tried by another user and apparently worked well.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...g#Using_Vesa_Drivers
If it is resources heavy, you have a low power CPU (assume it is a 1.8GHz P4 not 18GHz!) and minimal RAM which will not help.
I don't exactly understand the premise for your upgrade.
I would not want 2 monitors, I have enough trouble finding room out of the way of coolant and swarf, but still visible and usable, for one monitor.
Even the crappy gnome-ubuntu-gdm window manager setup that comes as standard with the Live CD gives you 2 workspaces.
You could run Linuxcnc in one and have docs or whatever open in the other.
If you installed a decent window manager like iceWM it is 10x faster and you can have as many workspaces as you want (I have 9 on this machine).
Give the vesa drivers a go, but if all else fails you know it worked well on the old card
Last edit: 08 Jan 2013 22:19 by ArcEye.
Time to create page: 0.272 seconds
