Will this work?
08 Mar 2013 18:27 #31086 by smprobban
Will this work? was created by smprobban
Hi!
Was thinking of trying this hardware for a new linuxcnc
configuration what do you guys/girls think? Has somone tested it?
Motherboard: Intel D425KT
4GB DDR3
HDD SSD 32/64 GB
08 Mar 2013 18:56 #31087 by ArcEye
Replied by ArcEye on topic Will this work?
08 Mar 2013 20:36 #31089 by BigJohnT
Replied by BigJohnT on topic Will this work?
This board has been recommended lately.
ASUS E45M1-M PRO
The following user(s) said Thank You: smprobban
13 Mar 2013 14:56 - 13 Mar 2013 18:00 #31311 by smprobban
Replied by smprobban on topic Will this work?
ASUS E45M1-M PRO
Okey will it work with the paralleport or will i need something else? If we talk about CNC Sinumerik 3T as an example?
Last edit: 13 Mar 2013 18:00 by smprobban.
13 Mar 2013 19:50 #31321 by danemc
Replied by danemc on topic Will this work?
yeah it says it has a parport. it is a header on the board that gets a cable and db25 connector that mounts in the case rather than being mounted to the board directly. the latency on these looks pretty good and according to at least one thread some atom based boards though they report less latency they actually don't report the latency as reliably and wont run a pid loop as fast.
parallel ports work ok for step based output but i think a mesa fpga card may be needed for a retrofit on a cnc machine. a parallel port alone may be enough for a conversion that doesn't need a lot connected to it. which card is needed may depend on the existing servo controllers.
13 Mar 2013 21:09 #31325 by ArcEye
..............it is a header on the board that gets a cable and db25 connector that mounts in the case
If this is supplied with it, I am sure it is OK.
Just be aware that users of other boards with headers have found that the header is 26 pin and when a ribbon connector is plugged
in, pin 26 actually lines up with the red striped wire in the ribbon cable (pin 1) !
Causes all sorts of problems because your pins are all backwards
Time to create page: 0.069 seconds
