KVM Switches (DVI and USB)
- ScottBouch
18 Mar 2013 23:18 #31548
by ScottBouch
KVM Switches (DVI and USB) was created by ScottBouch
Has anyone had any experience with using a KVM switch with EMC2/Ubuntu?
In my shed, I have one monitor (DVI or VGA input), a USB keyboard and mouse.
My PC for LinuxCNC has a DVI or VGA output.
My Raspberry Pi has an HDMI output (equivalent to DVI)
I want to stick to one monitor, keyboard and mouse for both computers.
Can Ubuntu get upset when live connecting and disconnecting DVI and USB devices?
Cheers, Scott
Cheers, Scott
- ArcEye
- Thank you received: 758
18 Mar 2013 23:54 #31551
by ArcEye
Replied by ArcEye on topic KVM Switches (DVI and USB)
Hi
When I was testing a RPi. I had it plugged into the HDMI slot on my monitor and the main computer plugged into VGA, so I didn't use a switch, just selected the input from the monitor.
Ubuntu should be pretty much plug and play regards USB HID, you can unplug and replug a mouse in no problem and you can even plug another keyboard in and it will take input from both.
The image on your RPi may not be so forgiving, depends what it is, give it a go
- ScottBouch
19 Mar 2013 02:13 #31554
by ScottBouch
Replied by ScottBouch on topic KVM Switches (DVI and USB)
Thanks Arc Eye,
I do use 2 PC's at work on the same monitor as you described, one DVI, one VGA... But it means having 2x Keyboard & Mouse on my desk which can get messy at times (typing into the wrong computer!)
Also, the difference beteeen VGA and DVI on terms if sharpness, user friendliness etc makes VGA feel very old hat (which it is... It's amazing VGA has stood the test of time as long as it has!)
I'll have a play with the Pi to see if it recognises devices being disconnected and re connected repeatedly.
Just wanted to be sure brgore I bought a switch that thrre are no known issues with LinuxCNC.
Could unplugging and reconnecting during machining cause a mess?
Thanks, Scott
Thanks, Scott
- Thank you received: 5013
19 Mar 2013 04:46 #31560
ssh -X might suit. That way you can run the Pi headless. Then keyboard/mouse input simply goes to the selected window.
I do it a lot.
Replied by andypugh on topic KVM Switches (DVI and USB)
I do it a lot.
- ScottBouch
19 Mar 2013 05:45 #31565
by ScottBouch
Hi Andy, good low budget idea! Thanks!
Time to create page: 0.230 seconds
