Has anyone tried this Mini?
21 May 2013 01:37 - 21 May 2013 02:00 #34461 by submicro
Replied by submicro on topic Has anyone tried this Mini?
Thanks John I'd appreciate that.
drop me an e-mail
submicro68 at gmail
P.S. I live in Missouri KC area
I'd really like to explore the potential extra I/O's from the second para port. If it didn't have that I'd just go with the other one. I'm just worried about it's performance.
Last edit: 21 May 2013 02:00 by submicro.
21 May 2013 03:12 #34463 by BigJohnT
Replied by BigJohnT on topic Has anyone tried this Mini?
As far as LinuxCNC goes it will do fine, just don't try and do big graphics applications IIRC.
JT
21 May 2013 04:13 #34468 by submicro
It would be used as a dedicated machine controller running Linuxcnc. Can you tell me what the latency numbers are?
21 May 2013 04:30 #34471 by BigJohnT
They were pretty good, IIRC the numbers were in the NC Box thread somewhere.
JT
The following user(s) said Thank You: submicro
21 May 2013 15:17 #34487 by ArcEye
Replied by ArcEye on topic Has anyone tried this Mini?
See the later pages of the thread re this.
It is not a parallel port but GPIO arranged into 3 banks of pins. Takes a standard ribbon cable plug, I cut an IDE cable down for the tests.
Seems pretty useful and I think you can designate IN or OUT, so no wasted OUT pins you don't need.
You may have some issues upgrading to the 2.6.30 kernel I built if you want it networked.
I have just been through it all recently with another member who is using one so hopefully it is all fresh in my mind if you have problems.
21 May 2013 23:15 - 21 May 2013 23:15 #34510 by submicro
Thanks I Appreciate the help. The extra I/O's are what I'm most interested in.
Last edit: 21 May 2013 23:15 by submicro.
03 Jun 2013 01:19 - 03 Jun 2013 02:35 #35152 by submicro
Sorry never mind
Last edit: 03 Jun 2013 02:35 by submicro.
Time to create page: 0.076 seconds
