Touchscreen with LinuxCNC
- conorm
Wondering if anyone has been able to use one of the N-trig capacitive touch screens successfully with LinuxCNC. Its a usb touch screen on an LG panel I'm trying to use as an all-in-one CNC control box. I've tested the screen both on windows and ubuntu 12.04LTS (run off a usb), both of which ran the touch well. So I'm confident its just a driver issue. I'm running the latest download of LinuxCNC, 10.04.
Right now, I'm able to run the screen and it does seem to recognize a 'touch' but will not recognize location. If I plug in the usb for the touch, wherever I touch on the screen the pointer moves to the top left hand corner and will only recognize a touch as a click. No amount of swiping or location of the touch seems to make a difference.
running lsinput outputs the following:
/dev/input/event7
bustype : BUS_USB
vendor : 0x1b96
product : 0x7
version : 272
name : "N-trig DuoSense"
phys : "usb-0000:00:13.0-3/input1"
uniq : "11.20.10.53.16"
bits ev : EV_SYN EV_KEY EV_ABS EV_MSC
I've tried loading the driver shown here: Post 18359 , but with no real results. I also tried loading the HidTouch Suite off of sourceforge, but seemed to have issues trying to compile onto the real time kernel.
Thanks in advance for any suggestions.
- Thank you received: 4970
Does the manufacturer have a calibration routine? My touchscreen was mirrored and rotated until I calibrated.
You may need to create an Xorg.conf file and put some stuff in there.
- conorm
I don't know of any manufacturer calibration, though I was able to get xinput_calibrator set up. It didn't seem to recognize the touch, though the output from that is here:Does the manufacturer have a calibration routine? My touchscreen was mirrored and rotated until I calibrated.
Absolute events.
Warning: multiple calibratable devices found, calibrating last one (N-trig DuoSense)
use --device to select another one.
DEBUG: Selected device: N-trig DuoSense
DEBUG: Not usbtouchscreen calibrator: Not a usbtouchscreen device
DEBUG: Read axes swap value of 0.
DEBUG: Read InvertX=0, InvertY=0.
Calibrating EVDEV driver for "N-trig DuoSense" id=12
current calibration values (from XInput): min_x=0, max_x=0 and min_y=0, max_y=0
DEBUG: Found that 'N-trig DuoSense' is a sysfs name.
To be honest, I'm fairly new to linux, so i'm not sure exactly how to go about this or what I would be needing to put into that file.You may need to create an Xorg.conf file and put some stuff in there.
- ArcEye
- Thank you received: 758
From what I have read here
wiki.ubuntu.com/Multitouch/HardwareSupport
it is unlikely that anything before Ubuntu 10.10 will support it and maybe not until 12.xx from other threads on the Ubuntu forum
This wiki is for edubuntu but same principles apply, first test, does it get detected on kernel boot ( check dmesg ), if not that is the end of it.
wiki.edubuntu.org/X/Testing/Touch
- cncbasher
- Thank you received: 288
- conorm
for further reading
ubuntuforums.org/showthread.php?t=1252492
Thanks, I had gone through the steps on this, but no luck on getting any response from the touchscreen. I may go back and run through with the wacom driver and see if that works,though.
I was initially thinking that 10.10 support was only for the multitouch capability and not basic functionality with pen or single finger input. I went through the steps on the second link and it seems that while it does recognize the screen as an input device, it doesn't recognize it as a touchscreen. Which is basically what I've been experiencing in terms of functionality. So you think i'm totally SOL with getting the touchscreen working with linuxcnc, or is just going to require a custom driver for the realtime kernel to be put together?
Hi
Thanks again
- ArcEye
What it will require is a rt kernel based upon a kernel that does support it.
Have a look at the xenomai kernel packages which run on 12.04 / 12.10. They are based on kernel 3.5.7 which certainly should support it
wiki.linuxcnc.org/cgi-bin/wiki.pl?XenomaiKernelPackages
- conorm
Thanks ArcEye, that helped a lot. So i've got the touch working on 12.04 running the xenomai kernel. I did have to run through a few more steps in terms of getting the parallel port working with linuxcnc. So everything on that end seems to be running well. But, now I've got a new issue of not being able to get linuxcnc running. I seem to be having a similar issue to the one you were trying to help out with greenbuggy ( post 33595 ). I'm getting a simmilar boot error where it'll crash trying to start up axis.
I realize this maynot be the most helpful, but here is the output from linuxcnc_print:
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/minibox/emc2-dev/bin
LINUXCNC_TCL_DIR=/home/minibox/emc2-dev/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/minibox/emc2-dev/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/minibox/emc2-dev/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/minibox/emc2-dev/configs/gecko/Gecko_540B3/Gecko_540B3.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Killing task linuxcncsvr, PID=4715
I'll try and get you the output from terminal, but the config.log and kern.log should be attached if you know of what the issue might be.
Thanks again
- conorm
edit: think the file size was too large.
- ArcEye
