New computer for linuxcnc
- grandixximo
- Thank you received: 10
28 Aug 2013 16:23 - 28 Aug 2013 16:32 #38184
by grandixximo
Replied by grandixximo on topic New computer for linuxcnc
As you advised the on-board video chipset does have better results,without the video card drivers installed the latency is sligtly better but the graphics are worse than with the on-board video, whith drivers installed i get latency spikes up to 30000
Today i also had a go with Ubuntu Pangolin Precise 12.04 and the xenomai realtime kernel, i get worse latency results with and without the video card
graphically is much better, but in latency the results are very bad.
I really tough the new realtime was better, i should try harder with maybe isolcpu=1 but it works so good on 10.04
Last edit: 28 Aug 2013 16:32 by grandixximo.
- ArcEye
- Thank you received: 758
28 Aug 2013 17:03 - 28 Aug 2013 17:04 #38185
by ArcEye
Replied by ArcEye on topic New computer for linuxcnc
Hi
xenomai works, but I have always got worse jitter figures with it than rtai
If you have servos or hardware stepgens that probably does not matter, but for software stepper setups, it was too high on my machines
Try these packages on 12.04.
I tested Sebs first ones on a 3.4.xx kernel and they worked fine
highlab.com/~seb/linuxcnc/rtai-for-3.5-prerelease/
I only achieved better figures than these, with my own homebrew 3.5.7-rtai kernel, which I had tuned to the computer and was ruthless with all power management etc
PS Because it is RTAI, the isolcpus kernel parameter should do more with this kernel too
Last edit: 28 Aug 2013 17:04 by ArcEye.
- grandixximo
28 Aug 2013 17:29 #38186
by grandixximo
which package should i install all of them?
- ArcEye
28 Aug 2013 18:29 #38187
by ArcEye
You just need
linux-image
linux-headers
rtai-modules
There are 2 rtai-modules, so I assume the one with ubuntu in the file name, don't know what the difference is, that has changed since i last looked.
linux-image
linux-headers
rtai-modules
- grandixximo
28 Aug 2013 19:04 - 28 Aug 2013 20:46 #38189
by grandixximo
Just one more question, should i build linuxcnc from the source for xenomai or from the normal 2.5 source?
EDIT:
i builded from the linuxcnc xenomai compatible source, it works now with the new rtai on ubuntu 12.04
i followed this
wiki.linuxcnc.org/cgi-bin/wiki.pl?NewRTInstall
The jitter is much lower than with xenomai, i had to use isolcpu=1 tough to get low jitter, now it works fine
EDIT:
i followed this
Last edit: 28 Aug 2013 20:46 by grandixximo.
- ArcEye
29 Aug 2013 00:14 #38196
by ArcEye
That is what I was going to suggest.
I have also built a single processor version of 3.5.7-rtai and installed on my workshop machines
I am actually getting lower latency heavily loaded running this on Wheezy (7K) on P4 2.4GHz than I was running 8.04 on them (9K)
We live in interesting times
i followed this
- TarHeelTom
01 Nov 2013 23:13 #40492
by TarHeelTom
Replied by TarHeelTom on topic New computer for linuxcnc
My mill has been down for about a year looking for a limit switch. Finally discovered that Allied Electronics has an excellent selection of Honeywell micro switches.
Installed the new switch last night, and found that my PC (old D525) is dead.
Looking on Newegg this morning, and found these two items:
N82E16819116405 cpu
N82E16813128537 motherboard
But I still need an additional parport card. What card do I need with this motherboard?
Tom
N82E16819116405 cpu
Tom
- ArcEye
01 Nov 2013 23:37 #40494
by ArcEye
Hi
It appears to have 1 parport plus 2 PCI and 1 PCIe slots
You can just use a netMos (Moschip) based PCI card (9845 9865 9901) unless you need to use EPP mode in which case their implementation is flakey and
the Oxsemi (PLXTech now) OX16PCI954 is recommended by PCW I think for FPGA cards.
Time to create page: 0.081 seconds
