High latency on supposedly appropriate PC
27 Aug 2013 21:12 #38153 by gaeldk
Hello,
Yes, yet another post on latency issues.
I get really high numbers above 250000 just by starting Firebox or Glxgears.
My Linuxcnc dedicated PC is old but I thought good enough for the task:
Amd Athlon64 X2 4400+ (dual core)
Nvidia 7800 GTX
2Go of RAM
The lscpi -vv listing is attached...
File Name: amdcomp.txt
File Size:15 KB
So I have seen a lot of different things/hacks to attempt reducing the latency but before I mess up everything, I'd like to know what is the obvious thing to start with on my computer.
Thanks a lot.
27 Aug 2013 22:51 #38158 by ArcEye
Replied by ArcEye on topic High latency on supposedly appropriate PC
Hi
Rather sounds as though video is the area to probe first
01:00.0 VGA compatible controller: nVidia Corporation G70 [GeForce 7800 GTX] (rev a1)
Kernel driver in use: nvidia
Kernel modules: nvidia-173, nvidiafb, nouveau
You have the nvidia proprietary driver from the restricted packages installed (nvidea-173)
The way that nvidia drivers do openGL has been linked to a lot of problems with latency
You can remove nvidea-173 and the card will work with nouveau (the open source driver)
This gives a start, you may have to google further
askubuntu.com/questions/12937/remove-nvi...d-go-back-to-nouveau
See what effect that has first, the next step might be to add isolcpus=1 to the kernel boot line, but one thing at a time so you can be clear what had which effect B)
28 Aug 2013 00:49 #38164 by gaeldk
Replied by gaeldk on topic High latency on supposedly appropriate PC
Thank that did work very well, now max at 11000 whith to glxgears and youtube playing HD content...
The start of Firefox happens without a spike...
Now the only issue is that this "nouveau" driver seems to do soft OpenGL and Blender will then be very slow...
28 Aug 2013 01:35 #38168 by ArcEye
It doesn't do 3D accelerated thats for sure, but you want a stable low latency machine controller.
It will be fast enough for that
Time to create page: 0.065 seconds
