thoughts on motherboard processor combo
- acecore
22 Oct 2013 19:42 - 22 Oct 2013 19:44 #40167
by acecore
thoughts on motherboard processor combo was created by acecore
Just looking for some thoughts on this mobo combo. Can anyone find any issues i may have with it? checked the cnc latency site and the board is'nt listed.
www.maplin.co.uk/msi-e350-apu-amd-fusion...therboard-kit-652617
Sorry forgot to add ill be using this to retro fit a bridgeport mill using mesa 5i25-7i77
Last edit: 22 Oct 2013 19:44 by acecore.
- ArcEye
- Thank you received: 758
22 Oct 2013 22:21 #40175
by ArcEye
Replied by ArcEye on topic thoughts on motherboard processor combo
Hi
Looks like the AMD equivilent to the Intel Atom, similar specs on quite a few things.
However 3 PCI slots (2 PCIe) and proper parport, not a header.
The graphics chip may not be supported with an open source driver until at least kernel 3.1 and above (min Ubuntu 12.11 with upgrade or 13)
The proprietary AMD/ATI driver fglrx has been linked to latency problems in the past
If this means hardware step generation or servos, it may do you fine, latency is not really an issue in that case.
Until someone tries one, just guessing
- Thank you received: 4966
23 Oct 2013 17:38 #40221
It certainly seems inexpensive enough, given that memory is included. But it seems like you have to be the guinea-pig.
The only way that it could be better is if it was 12V suppply rather than ATX PSU.
Note that with 4GB of memory there is a change that the Ubuntu installer will throw away the realtime kernel and replace it with a large-memory kernel (without realtime)
(Not a huge problem, just something to be aware of if you find that LinuxCNC doesn't seem to work)
Replied by andypugh on topic thoughts on motherboard processor combo
Time to create page: 0.111 seconds
