Probotix Linuxcnc Computer
21 Dec 2013 22:54 - 21 Dec 2013 23:02 #41906 by Davenc
Probotix Linuxcnc Computer was created by Davenc
I've got two of these atom based pc's from probotox and they are cheap, work great and have the latest linuxcnc installed on them.
probotix.com/accessories/
Go down to the bottom of the page and you'll see it. This was the cheapest PC I could find that was setup for linuxcnc without me having to build one myself.
Last edit: 21 Dec 2013 23:02 by Davenc.
22 Dec 2013 00:48 - 22 Dec 2013 00:49 #41908 by ArcEye
Replied by ArcEye on topic Probotix Linuxcnc Computer
Hi
I moved this to a topic of its own
Nice to see someone selling a computer they have tested with Linuxcnc and with everything pre-installed
Will suit a lot of users
Can you do a full latency test and post the results plus the full spec of the computer
I will put it on the wiki.
Last edit: 22 Dec 2013 00:49 by ArcEye.
24 Dec 2013 07:14 - 24 Dec 2013 07:15 #41959 by Davenc
Replied by Davenc on topic Probotix Linuxcnc Computer
I ran the latency test overnight and the numbers are below.
Servo thread Max Jitter was 11,097
Base thread Max Jitter was 13,238
This is all they have on their website and I added what I thought was missing, what else do you need?
Ubuntu/LinuxCNC Control Computer
Features:
1.5Ghz Mini-ITX Motherboard
1GB RAM
250GB Hard Drive (The enclosure has an extra slot for another sata hard drive/optical drive)
Ubuntu 10.04/LinuxCNC Pre-installed
7 USB ports 5 in the back and 2 in the front
VGA monitor output
2 parallel ports
1 serial port
Wired Ethernet port
Sound card input/output/headphone jack
(No monitor, mouse, keyboard, or optical drive included)
Last edit: 24 Dec 2013 07:15 by Davenc.
24 Dec 2013 18:45 - 24 Dec 2013 18:45 #41973 by ArcEye
It is a bit generic, possibly not tying themselves to a particular board so they can change as they wish
sudo apt-get install hwinfo
hwinfo --log hardware.log
and attach the hardware.log to a post please
Last edit: 24 Dec 2013 18:45 by ArcEye.
25 Dec 2013 01:23 #41987 by Davenc
Hwinfo installed fine but the logfile is empty, the properties of the file show 0 bytes. I ran it without the logfile option and there is quite a bit of data generated from the program so the program is working.
25 Dec 2013 02:21 #41990 by PCW
Replied by PCW on topic Probotix Linuxcnc Computer
looks like a hwinfo bug
hwinfo --short --log hardware.log
works
Note you should use
hwinfo --short --log hardware.txt
If you are going to post the info here since only a few file types are accepted
(.txt being one of the OK ones)
25 Dec 2013 03:19 - 25 Dec 2013 03:19 #41992 by Davenc
Ok that worked and heres the data.
Last edit: 25 Dec 2013 03:19 by Davenc.
The following user(s) said Thank You: ArcEye
01 Jan 2014 17:25 - 01 Jan 2014 17:29 #42259 by ArcEye
Now added thanks, sorry for delay getting back
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
Last edit: 01 Jan 2014 17:29 by ArcEye.
Time to create page: 0.175 seconds
