HP DC7600 - Latency not as reported in the wiki
- ArcEye
- Thank you received: 758
Having read the SMI fix wiki, it's not clear how I should go about compiling it for a RIP environment on a custom kernel.
You don't need to, it is a part of realtime code not the kernel
You should find it already compiled in /usr/realtime/modules (or at least it will be in the deb you downloaded for my 3.5.7-rtai, I don't know what is in Sebs packages)
I know nothing about hardware stepping - is that a solution that will run on ANY old PC that can run LinuxCNC?
Pretty much, so long as you have a decent servo thread.
One of Peters Mesa boards (might be one main card and a daughter card, I am not very au fait on them) or Jon Elsons Pico boards
will provide hardware generated pulses independent of the PC, leaving it free to do the interpreter bit etc
It also will provide hugely increased I/O connections, breaking the 17 pins per parport limit.
The only downside is increased cost
www.mesanet.com/fpgacardinfo.html
pico-systems.com/
- ArcEye
Only because thus far I have been able to get software stepping to work well enough for my requirements, though the use of low latency computers and designer rtai kernels.
Michael H laughs at me compiling custom kernels and running P4s, when I could just add FPGA card and spend the time on something else.
But each to their own, I have become boringly familiar with all aspects of kernel, realtime and linuxcnc compilation in the process and my hardware is never going to stop working for lack of a suitable
rtai system at least
- birchy
Oh yes, so it is...DUH.You should find it already compiled in /usr/realtime/modules
Where is rtapi.conf? "find / -name *rtapi.conf*" finds nothing. Or is there some other way to make the SMI module load?
EDIT:
Yeah, I can see the benefits of hardware stepping but I'm too far into the build to be considering rewiring, however it's certainly something to consider for future builds.
- birchy
BIOS is fully optimized and I've disabled all unused services using rcconf. Results are the same with all my graphics cards and there's not much difference between using PS2 or USB mouse/keyboard. I'm pretty much out of options!
Only other question is regarding IRQ's in BIOS. I notice there's a page that sets the IRQ's for VGA, USB, Network, SATA and Audio. Options are: IRQ5, IRQ10, IRQ11 and Disable. I've set audio to disable but am wondering if there are some conflicts as the default settings put VGA and Network on IRQ5 and then use IRQ10 and IRQ11 for the USB ports and SATA. Is there any mileage to be had here or am I clutching at straws?
Also, HDD is SATA rather than IDE. I don't think it causes any issues, but thought I'd mention it just in case...
- Thank you received: 5205
EDIT:
Actually you can mimic any parallel port pinout with any of the MESA's 25 pin FPGA
cards and there are 3 standard pinouts for parallel port breakouts.
- ArcEye
You can but try.
I haven't had to change IRQs for years, since the days when some cards were flakey and if you let IRQs be allocated automatically, they conflicted with other cards.
You could even disable the network and see if it has any effect, since it is easy to reinstate when you need it.
There is probably a T junction ahead, one way is signposted 'FPGA' and the other 'Rewind & Try Again'
- birchy
On the plus side, my old AMD K8 rig runs at about 16K with the Radeon AGP cards, so is usable. Fingers crossed, the Matrox will improve the latency.
If all else fails, I'll probably splash £50 on a Gigabyte E350N with the AMD cpu as they are reported as giving <5K latency.
The Beaglebone Black is tempting but looks very experimental and I'm not ready for another learning curve (yet)...
- Skippy1
- Thank you received: 4
While trying different PCs, I did jag a nice one - an ACER 5900pro with a jitter of 5000 - 6000. Boy this PC was rock-solid, even without a separate graphics card or anything fancy. I listed the results on the Latency Test Wiki, but mistakenly listed it as an ASUS and later couldn't work out how to fix it. I didn't use it in the end as the chassis was too big for the space I had in the cabinet.
Anyway, best of luck with the 'jitters'.
Steve
- ArcEye
I have edited your entry and moved the whole database back into something approximating alphabetical order.
