nertmos 9865 problem "in"
- lorisdag
16 May 2014 16:19 #46974
by lorisdag
nertmos 9865 problem "in" was created by lorisdag
hello I can not configure the port lpt NetMos 9865 chip input, even if I put "in" the door is still out, where am I wrong?thanks
- ArcEye
- Thank you received: 758
16 May 2014 17:20 #46975
by ArcEye
Replied by ArcEye on topic nertmos 9865 problem "in"
Hi
Can you attach your .hal file and do lspci -vv > lspci.txt and attach the lspci.txt that results
- lorisdag
17 May 2014 03:19 #46994
by lorisdag
Replied by lorisdag on topic nertmos 9865 problem "in"
hello, here are the files I'm doing tests with estop. thanks
- lorisdag
17 May 2014 03:21 #46995
by lorisdag
loris-cnc lspci
- lorisdag
17 May 2014 03:22 #46996
by lorisdag
loris@loris-cnc:~$ su
Password:
root@loris-cnc:/home/loris# lspci -vv > lspci.txt
00:00.0 Host bridge: ALi Corporation M1689 K8 Northbridge [Super K8 Single Chip]
00:01.0 PCI bridge: ALi Corporation AGP8X Controller
00:02.0 PCI bridge: ALi Corporation M5249 HTT to PCI Bridge
00:03.0 ISA bridge: ALi Corporation M1563 HyperTransport South Bridge (rev 70)
00:03.1 Bridge: ALi Corporation M7101 Power Management Controller [PMU]
00:04.0 Multimedia audio controller: ALi Corporation M5455 PCI AC-Link Controller Audio Device (rev 20)
00:0d.0 Ethernet controller: ALi Corporation ULi 1689,1573 integrated ethernet. (rev 40)
00:0e.0 IDE interface: ALi Corporation M5229 IDE (rev c7)
00:0e.1 Mass storage controller: ALi Corporation ULi 5289 SATA (rev 10)
00:0f.0 USB Controller: ALi Corporation USB 1.1 Controller (rev 03)
00:0f.1 USB Controller: ALi Corporation USB 1.1 Controller (rev 03)
00:0f.2 USB Controller: ALi Corporation USB 1.1 Controller (rev 03)
00:0f.3 USB Controller: ALi Corporation USB 2.0 Controller (rev 01)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:00.0 VGA compatible controller: ATI Technologies Inc RV350 AS [Radeon 9550]
01:00.1 Display controller: ATI Technologies Inc RV350 AS [Radeon 9550] (Secondary)
02:05.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller
02:06.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller
02:07.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller
02:08.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller
Password:
- lorisdag
17 May 2014 03:23 #46998
by lorisdag
loris@loris-cnc:~$ lspci -vv
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Region 0: Memory at c0000000 (32-bit, prefetchable) [size=256M]
Capabilities: <access denied>
Kernel driver in use: agpgart-amd64
Kernel modules: amd64-agp, ali-agp
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: fbe00000-fbefffff
Prefetchable memory behind bridge: d0000000-faffffff
Secondary status: 66MHz+ FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity+ SERR+ NoISA- VGA+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel modules: shpchp
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=64
I/O behind bridge: 0000d000-0000efff
Memory behind bridge: fbf00000-fbffffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity+ SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
Subsystem: ALi Corporation M1563 HyperTransport South Bridge
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0 (250ns min, 6000ns max)
Kernel driver in use: ali1563_smbus
Kernel modules: i2c-ali1563
Subsystem: ALi Corporation M7101 Power Management Controller [PMU]
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Kernel modules: alim7101_wdt, i2c-ali15x3, i2c-ali1535
Subsystem: ASUSTeK Computer Inc. Device 810d
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 18
Region 0: I/O ports at b800
Region 1: Memory at fbdff000 (32-bit, non-prefetchable) [size=4K]
Kernel modules: snd-intel8x0
Subsystem: ASUSTeK Computer Inc. Device 816a
Latency: 64 (5000ns min, 10000ns max)
Interrupt: pin A routed to IRQ 17
Region 0: I/O ports at b400
Region 1: Memory at fbdfec00 (32-bit, non-prefetchable)
Kernel driver in use: uli526x
Kernel modules: uli526x
00:0e.0 IDE interface: ALi Corporation M5229 IDE (rev c7) (prog-if fa)
Subsystem: ALi Corporation M5229 IDE
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32
Interrupt: pin A routed to IRQ 19
Region 0: [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled]
Region 1: [virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled]
Region 2: [virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled]
Region 3: [virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled]
Region 4: I/O ports at ff00
Kernel driver in use: pata_ali
Kernel modules: pata_ali
00:0e.1 Mass storage controller: ALi Corporation ULi 5289 SATA (rev 10) (prog-if 8f)
Subsystem: ASUSTeK Computer Inc. Device 816b
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 128, Cache Line Size: 512 bytes
Region 0: I/O ports at bc00
Region 1: I/O ports at b080
Region 2: I/O ports at b000
Region 3: I/O ports at ac00
Region 4: I/O ports at a880
Kernel driver in use: sata_uli
Kernel modules: sata_uli
00:0f.0 USB Controller: ALi Corporation USB 1.1 Controller (rev 03) (prog-if 10)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx+
Latency: 64 (20000ns max), Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 20
Region 0: Memory at fbdf3000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
00:0f.1 USB Controller: ALi Corporation USB 1.1 Controller (rev 03) (prog-if 10)
Interrupt: pin B routed to IRQ 21
Region 0: Memory at fbdfc000 (32-bit, non-prefetchable) [size=4K]
00:0f.2 USB Controller: ALi Corporation USB 1.1 Controller (rev 03) (prog-if 10)
Interrupt: pin C routed to IRQ 22
Region 0: Memory at fbdfd000 (32-bit, non-prefetchable) [size=4K]
00:0f.3 USB Controller: ALi Corporation USB 2.0 Controller (rev 01) (prog-if 20)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 64 (4000ns min, 8000ns max), Cache Line Size: 64 bytes
Interrupt: pin D routed to IRQ 23
Region 0: Memory at fbdfe800 (32-bit, non-prefetchable)
Kernel driver in use: ehci_hcd
Kernel driver in use: k8temp
Kernel modules: k8temp
Subsystem: PC Partner Limited Device 0200
Latency: 64 (2000ns min), Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 16
Region 0: Memory at d0000000 (32-bit, prefetchable) [size=256M]
Region 1: I/O ports at c000
Region 2: Memory at fbee0000 (32-bit, non-prefetchable) [size=64K]
Expansion ROM at fbec0000 [disabled] [size=128K]
Kernel driver in use: radeon
Kernel modules: radeonfb, radeon
Subsystem: PC Partner Limited Device 0201
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Region 0: Memory at e0000000 (32-bit, prefetchable) [size=256M]
Region 1: Memory at fbef0000 (32-bit, non-prefetchable) [size=64K]
02:05.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
Subsystem: Device a000:2000
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 64, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 3
Region 0: I/O ports at ec00
Region 1: I/O ports at e880
Region 2: Memory at fbfff000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at fbffe000 (32-bit, non-prefetchable) [size=4K]
02:06.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
Interrupt: pin A routed to IRQ 11
Region 0: I/O ports at e800
Region 1: I/O ports at e480
Region 2: Memory at fbffd000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at fbffc000 (32-bit, non-prefetchable) [size=4K]
02:07.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
Interrupt: pin A routed to IRQ 5
Region 0: I/O ports at e400
Region 1: I/O ports at e080
Region 2: Memory at fbffb000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at fbffa000 (32-bit, non-prefetchable) [size=4K]
02:08.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
Interrupt: pin A routed to IRQ 10
Region 0: I/O ports at e000
Region 1: I/O ports at dc00
Region 2: Memory at fbff9000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at fbff8000 (32-bit, non-prefetchable) [size=4K]
loris@loris-cnc:~$
Latency: 0
Latency: 0
Latency: 0
Latency: 32
loris@loris-cnc:~$
- lorisdag
17 May 2014 03:26 #46999
by lorisdag
loris@loris-cnc:~$
loris@loris-cnc:~$
- ArcEye
17 May 2014 15:25 #47012
by ArcEye
Hi
Something very strange going on with the text display on the forum, saw it on another post too.
I am not convinced that the two ports you have specified, are actually the ports.
The MosChip (NetMos) PCI boards tend to list the higher address first, but this is usually the register and the port is the lower address.
I don't know how you are testing this, but if you are looking in HAL Configuration, it can sometimes apparantly list all the pins of a port that does not exist, but you cannot do anything with it.
Try loadrt hal_parport cfg="0x378 out 0xe880 in 0xe400 in "
That would put the port 0x400 below the register, which is where it should be
loadrt hal_parport cfg="0x378 out 0xec00 in 0xe800 in "
Time to create page: 0.090 seconds
