Priorities for RT-Preempt Kernel
- t1m0n
08 Jul 2014 03:14 #48510
by t1m0n
Priorities for RT-Preempt Kernel was created by t1m0n
I'am using a kernel with real time preemption patch, the rt preempt kernel.
See www.kernel.org/pub/linux/kernel/projects/rt/.
I have to change the priorities to get the best result.
Actually, it is no problem to get real time for my applications, but I have to change the priorities of the processes for mouse and keyboard.
I want to use ps/2 but I don't know the name of the processes.
What is the name of the processes which handle mouse and keyboard?
- ArcEye
- Thank you received: 758
08 Jul 2014 15:15 #48522
by ArcEye
Replied by ArcEye on topic Priorities for RT-Preempt Kernel
Which version of Linuxcnc are you running on this kernel?
I you want a rt kernel that just works, install Wheezy and fetch the rt version of the kernel.
No need to mess about with priorities for mouse and keyboard, USB ones work properly
It will run MachineKit and Linuxcnc master with ubc-3 branch or jepler/rtos-uspace-apis branch checked out
- t1m0n
08 Jul 2014 19:05 - 08 Jul 2014 19:06 #48535
by t1m0n
I use Ubuntu 10.04 with Kernel 3.4.9-rt17
Replied by t1m0n on topic Priorities for RT-Preempt Kernel
I use this Version gitorious.org/emc-rt-preempt/emc-rt-pree...5cef9908c911749a363e: because of the shared memory interface.Which version of Linuxcnc are you running on this kernel?
Last edit: 08 Jul 2014 19:06 by t1m0n.
- ArcEye
08 Jul 2014 20:57 - 08 Jul 2014 21:06 #48542
by ArcEye
I had not heard of that fork, the last activity seems to be 2 years ago with a merge of 2.5.
You will find the MachineKit is bang up to date, because it still tracks Linuxcnc, is being worked on heavily and builds on rtai, rt, and xenomai
github.com/machinekit/machinekit.git
That is all I use now, on rt-preempt in the house and rtai in the workshop, all on Wheezy.
Whilst doing some searches I found a lot of references to rpi preempt kernel having problems with keyboard and mice
It was something to do with the priority given to usb.
Do a ps -A on your system
kpsmoused is a good place to start
(The modules tend to be hid_generic, usbhid, usbcore, unless you have a special kbd - mouse)
( PS I don't know if the vanilla kernels still have the PS/2 modules, a lot of distros seemed to drop support around 3.2 )
Last edit: 08 Jul 2014 21:06 by ArcEye.
Time to create page: 0.061 seconds
