Advice on PC configuration
01 Aug 2014 11:30 #49374 by mristau
Advice on PC configuration was created by mristau
Need help on configuring a PC to run LinuxCNC for "The Creation Station Open Source CNC Router by Innovation Squared."
Any feedback most appreciated. This is what I'm now looking at:
Gigabyte LGA 1155 DDR3 1333 Intel H61 HDMI Micro ATX Intel Motherboard with UEFI BIOS GA-H61M-HD2
www.amazon.com/Gigabyte-Intel-Micro-Moth...0VMZJ01HKE7S4FYFF3K5
Intel Celeron G1610 2.60GHz LGA 1155 Processor BX80637G1610
www.amazon.com/Intel-Celeron-2-60GHz-Pro...BJYVU/ref=pd_cp_pc_0
PNY OPTIMA 2GB (2x1GB) Dual Channel Kit DDR2 667 MHz PC2-5300 Desktop DIMM Memory Modules MD2048KD2-667
www.amazon.com/PNY-Channel-PC2-5300-Desk...0+MHz+memory+modules
Rosewill PCIe Parallel Card 1 Port Components Other RC-302E
www.amazon.com/Rosewill-Parallel-Compone...I-271+by+Synchrotech
01 Aug 2014 15:33 - 01 Aug 2014 15:56 #49384 by ArcEye
Replied by ArcEye on topic Advice on PC configuration
Looks like an interesting project, but it is using kickstarter as a payment vehicle rather than enterprise funding.
No units have been dispatched yet, hope the product is as good as the presentation and that units are actually delivered.
Would not be my choice. Does not have a parport or header, does not have PCI slot only 1 x PCIe16 and 2 minis
Anything with UEFI BIOS is a negative, not a selling point, but getting hard to avoid.
Really looks best suited to a media server or something similar, are you going to be using a HDMI screen with your router?
Look at boards here
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
DDR 1333 board will not take DDR2 677 RAM, it won't fit and is the wrong voltage
If you have 2 slots and want 2GB, buy 1 x 2GB, otherwise to upgrade later you have to throw the 2 x 1GB away
Looks like it has a MosChip MS9900 chip so should be OK
Last edit: 01 Aug 2014 15:56 by ArcEye.
02 Aug 2014 23:12 #49445 by mristau
Replied by mristau on topic Advice on PC configuration
Thanks for the help!
Based on your notes it looks like the Gigabyte H61M-S2PV LGA 1155 Intel H61 Micro ATX 1333 Intel Motherboard will be a better choice - Yes?
Intel Pentium Dual Core G2030 LGA 1155 Processor BX80637G2030
Coolmax 300W M-ATX Power Supply CM-300
Do i understand correctly that instead of using the processor's graphics capability a graphics card is needed? If so, might you suggest one? (Will find a compatible monitor at local university surplus.)
02 Aug 2014 23:33 #49446 by ArcEye
Hi
2 users (or the same one twice) seem to have tested it with quite good latency - I personally have not tested one
It certainly has more realistic slots and ports, if you are looking at running a stepper powered machine, using software stepping.
Entirely depends on the video chip, there is no notes on the latency test to suggest that it was necessary with these boards, so should be no.
The notes do say the smi fix was necessary and isolcpus parameter used, so you will need to bone up on what that involves
www.linuxcnc.org/index.php/english/forum...-the-latency-problem
www.linuxcnc.org/index.php/english/forum...me-latency-solutions
04 Aug 2014 07:03 #49475 by sspeed33317
Replied by sspeed33317 on topic Advice on PC configuration
I also have a GA-H61M-S2PV on the way , made the mistake of not getting the correct PCI slot.
04 Aug 2014 07:37 - 04 Aug 2014 07:43 #49478 by mristau
Interested in what processor you plan to use.
my ram choice:
Crucial 4GB Kit (2GBx2) DDR3 1333 MT/s (PC3-10600) CL9 Unbuffered UDIMM 240-Pin Desktop Memory Modules CT2CP25664BA1339
and for bluetooth/ wifi:
Gigabyte Bluetooth 4.0/WiFi Expansion Card Components Other GC-WB867D-I
any thumbs up or down on this helpful to me. (my first computer build)
Last edit: 04 Aug 2014 07:43 by mristau. Reason: additions
04 Aug 2014 07:52 - 04 Aug 2014 07:52 #49479 by sspeed33317
reusing a i3-3220 LGA1155 from my mistake board :-)
Last edit: 04 Aug 2014 07:52 by sspeed33317.
Time to create page: 0.060 seconds
