Matrox 730-00 Millennium?
03 Oct 2014 05:33 #51741 by mristau
Matrox 730-00 Millennium? was created by mristau
Did buy the wrong card?
Looked through the Matrox site but can't find a driver and uncertain how to install for Debian/Wheezy.
Any pointers?
Thanks!
03 Oct 2014 14:51 - 03 Oct 2014 14:52 #51744 by ArcEye
Replied by ArcEye on topic Matrox 730-00 Millennium?
Hi
I have not used this specific card before but have had no problems with other ones from matrox.
Make sure you have firmware-linux-nonfree and xserver-xorg-video-mga installed.
Then install the card and ensure your BIOS is using it and not the internal chip if you have one.
Re-boot and see what happens, it should detect the card and use the mga driver.
Last edit: 03 Oct 2014 14:52 by ArcEye.
05 Oct 2014 08:32 #51793 by mristau
Replied by mristau on topic Matrox 730-00 Millennium?
Thanks for that. I ran the commands and the result was that the latest were already installed. The Matrox 730 was purchased used. I now see that the rig will not even boot if the card is in place. Likely a hardware problem.
Time to create page: 0.076 seconds
