dual purpose (hopefully) laptop for machine contro
- Goosey
24 Nov 2014 15:41 #53349
by Goosey
dual purpose (hopefully) laptop for machine contro was created by Goosey
I just passed my Maintenance Machinist test at school and am now into the CNC part. I want to get a laptop so I can run prg's like gwizard, cncsimulator pro, etc at home to double check my g-code, but would also like to keep an eye on being able to power my home cnc router on the same machine away from home...like at flea markets, etc. Version one of my cnc router used a desktop machine without chopper frequency control on the steppers and it did fine but was only pushing a Dremel for the spindle. I've since bought a 2.2kw water cooled spindle w/VFD drive.
I want to dual boot to win7/linuxcnc with the emphasis on the cnc control side...I can live with long waits for cnc calculations in software as long as my controller side is stable and not hesitant.
any opinions of what...if any laptops...would be appropriate?
- BigJohnT
- Thank you received: 1176
24 Nov 2014 20:34 #53351
by BigJohnT
Replied by BigJohnT on topic dual purpose (hopefully) laptop for machine contro
Laptops are not appropriate for CNC control because of the battery saving "features" built into laptops that will interrupt real time calculations being done. You can run a simulator (no realtime needed) on your laptop. For your machine look for a small motherboard like the J15000 or was it J18000 I can't remember now.
JT
JT
- ArcEye
- Thank you received: 758
24 Nov 2014 22:02 #53352
by ArcEye
The J1800 and J1900 based boards are the ones recommended by PCW, now that the kernel issue regards USB with these is fixed in the debian iso.
Replied by ArcEye on topic dual purpose (hopefully) laptop for machine contro
- Thank you received: 2160
25 Nov 2014 05:48 #53365
Replied by cmorley on topic dual purpose (hopefully) laptop for machine contro
While laptops are not usually recommend, some have had success.
Also depending on what you are doing a realtime error from time to time may not be the end of the world - particularly if using hardware stepping.
I'm not recommending - I'm telling you, that if I had a laptop lying around I would just try it.
look here for some systems tried (there are some laptops there)
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
- Thank you received: 4967
25 Nov 2014 21:46 #53396
You might struggle to find a laptop with a parallel port nowadays. There are PC-card parallel ports, but you need to be careful to get one that is a full p-port interface rather than simply a printer controller.
The Ethernet-connected Mesa cards might be a option.
For a portable system you could consider machinekit and the Beaglebone, using the laptop only as a remote GUI.
Replied by andypugh on topic dual purpose (hopefully) laptop for machine contro
Time to create page: 0.052 seconds
