my parport is line driver or open collector??
- bkt
- Thank you received: 113
02 Dec 2014 17:57 - 02 Dec 2014 17:59 #53599
by bkt
my parport is line driver or open collector?? was created by bkt
I'm a newby in this tipe of argument.... i use parallel port (ibm standard) in some linuxcnc project .... i already use stepper driver and brushless driver too but now i must chose other hardware (some mesa card and new type of brushless driver).
LinuxCNC command signals step and dir linedrive mode is this true? or do I have to check my parallel port anytime?
My parallel port go from 0V to 3.4 max. The second one Normaly I use only for digital input and output .... and work with 0-5Volt with push-pull resistance and usb 5V alimetation.
until now I never paid attention to this and everything went smoothly.
Last edit: 02 Dec 2014 17:59 by bkt.
- Thank you received: 5187
02 Dec 2014 22:42 #53605
Replied by PCW on topic my parport is line driver or open collector??
Parallel port outputs on the data pins (the ones normally used for step/dir) are push pull and TTL/CMOS 5V or 3.3V level
some of the control pins are open collector with pullups in some modes.
No parallel port pins are line driver type. Line driver suggests differential signaling where a pair of wires
convey each signal, Differential signaling is used for better noise immunity.
The following user(s) said Thank You: bkt
Time to create page: 0.065 seconds
