UPS setup question
08 Dec 2014 20:42 #53816 by Niko
UPS setup question was created by Niko
Hello,
I have a UPS that I would like to setup . I want the pc to start when power is applied, and shut down propperly when power is removed . I have read this topic Monitoring a UPS with nut on Debian or Ubuntu Linux , but had no luck . I tried the second method . The driver acts weird but connects . The UPS is an inform GUARDIAN 1000A . Any ideas how I can set it up ?
09 Dec 2014 00:03 #53824 by ArcEye
Replied by ArcEye on topic UPS setup question
Hi
Your first problem might be that according to the compatible UPS list for NUT, your UPS model either does not exist or is not supported
www.networkupstools.org/stable-hcl.html
It is not necessarily the end, just probably means they have never tested your model.
I have no personal knowledge, have toyed with the idea but not gone there yet.
This guide is rather verbose, but seems to cover everything
www.enlightenmentfun.com/ups-for-linux-s...ng-on-debian-ubuntu/
The following user(s) said Thank You: Niko
09 Dec 2014 14:46 - 09 Dec 2014 18:02 #53842 by Niko
Replied by Niko on topic UPS setup question
Hi ,
thank you for the quick reply . I know there is no dedicated driver for it but I hoped to run it reasonably well with another one . What I find weird is that the UPS is seen as Fry's Electronics . I still have to try the tutorial you posted .
I found this early shutdown .
I am still having issues with it but there is hope . nut monitor is immensely helpful
Last edit: 09 Dec 2014 18:02 by Niko.
Time to create page: 0.066 seconds
