DELL Inspiron 3147 latency test results
- Carniflex
08 Jan 2015 17:39 #54747
by Carniflex
DELL Inspiron 3147 latency test results was created by Carniflex
Seems like the new DELL laptop I have is not suitable really for LinuxCNC direct control of anything.
The machine is www.passmark.com/baselines/V8/display.php?id=33769614184
www.dell.com/us/p/inspiron-11-3147-laptop/pd
A 11.6'' netbook class ultraportable. Intel Pentium N3530 CPU which can boost up to ~2.7 GHz, integrated GPU, 4 GB of RAM and very slow HDD. No parallel port just 3 USB ports. Running LinuxCNC live from 2GB USB stick.
The 1ms thread latency is ~280 500 ns and 25 microsecond thread ~296 050 ns.
Is there somewhere a full list of latency tests available? I am thinking of assembling my first CNC gadget (for a start just a very simple stuff to learn how it works with 3 stepper motors and cheap off the shelf parts) and was planning to drive the steppers directly from a PC with the DB25 breakout board and H-Bridges (yeah that laptop does not have DB25 port either) with the help of LinuxCNC.
- ArcEye
- Thank you received: 758
08 Jan 2015 18:09 #54749
by ArcEye
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
Please add your results or post the full set of 4 values and I will add it
The current favorites are the J1800 and J1900 mini ITX boards
Replied by ArcEye on topic DELL Inspiron 3147 latency test results
The following user(s) said Thank You: Carniflex
- Carniflex
08 Jan 2015 18:27 #54751
by Carniflex
Thank You.
Motherboard: INSPIRON 11 3000 SERIES (INTEL(R)) - 314
CPU: INTEL(R) PENTIUM(R) QUAD CORE(TM) N3530
Other Hardware Comments: N3530 Pentium CPU 2.17 GHz, 4GB RAM, Running LinuxCNC 2.6 from live USB. Using integrated GPU. Max Interval (1ms): 1281160 Max Jitter(ns) 1.0 ms thread: 290360 Max Interval (25 us thread): 322030 Max Jitter (25 us thread): 297260
Replied by Carniflex on topic DELL Inspiron 3147 latency test results
Thank You.
- ArcEye
08 Jan 2015 18:40 #54756
by ArcEye
Updated to warn others
Time to create page: 0.078 seconds
