Motherboard ?
- bill516
All the pci port cards I have tried, have tested OK on the Big John Hal tester, with the led's lighting as they should with the corresponding button press. When I hooked up to the machine I could never get the z axis, pin 7 to reverse direction, untill I re-mapped the pins, even even my logic probe showed that the pin was not changing state when I pressed to change direction in the GUI. So after all this I am assuming that something on the MoBo is not right but I dont know what as every test I have tried has shown the parallel ports to be working properly except the onboard port.
Its probably a mute point as a new Mobo will fix it but has anyone any idea what it might be?
Bill
- ArcEye
- Thank you received: 758
If your sole fault is that Z will not reverse direction, I would suspect the driver or the wiring, most likely the later.
Swapping over drivers and wiring should quickly establish the area the fault is in, if the Z axis works fine attached to the X axis stuff for instance.
- bill516
As I said iin my first post its a mute point as replacing the motherboard would definitley cure the problem, but what on the motherboard would cause pin 7 not to work correctly for both the onboard post and pci cards.
Bill
- ArcEye
Nothing.
Far more likely to be a break in the parport cable or similar, try testing continuity from D25 plug which connects to the computer to the other end of the cable and thence onto the BOB if that is OK
- bill516
Bill
- ArcEye
Thats why I was wondering whether there was anything that would be common to the motherboard and pci slots.
At some point there must be a convergence between ports on the PCI bus and the built in IO ports, but my knowledge of the architecture gets very sketchy at this point.
They will be addressed and implemented by the same low level driver (parport) with each port having a mapped memory area.
Because each pin ends up being a memory address, it seems difficult to imagine a common fault between the two, when they are using different memory addresses,
but what do I know
- Online
- Thank you received: 5300
There is basically no commonality in the data path between LPC devices and PCI devices that would not have
global (machine crashing) consequences.
An external problem seems much more likely
* LPC bus = Low Pin Count bus, a simplified serial version of the the old ISA bus
- bill516
Bill
- blacksmith
Onboard parallel ports are almost exclusively LPC* bus devices on motherboards of the last 10 years or so.
Is the LPC bus inferior compared to an add-in card for Linux CNC?
- Online
a bit slower than PCI/PCIE add-in parallel port cards. This probably doesn't make much
practical difference as these times are small (full range is probably about 0.5 to 3 uSec for the fastest PCI to slowest LPC port) and only a few I/O cycles are used
