Which Linux distribution for new install?
20 May 2015 20:52 - 20 May 2015 21:01 #58895 by Jake
I am doing a new install on the office machine along with the machine I am going to use for the plasma/router table.
I saw the Wiki is showing Ubuntu 10.04 LTS
With 14.04 LTS out should I install that or stick with 10.04 LTS ??
Thanks everybody~!
Last edit: 20 May 2015 21:01 by Jake. Reason: dumb
20 May 2015 21:02 #58896 by ArcEye
Replied by ArcEye on topic Which Linux distribution for new install?
Hi
The trouble with wikis, is they sit there for ever, long after they are out of date
Go to the Home page
There are 2 supported distros, Ubuntu 10.04 based and Debian 7 (wheezy) based
10.04 is out of support from Ubuntu, so no new libs etc for it.
Wheezy is up to date and still supported by debian, but may not always run nicely on older hardware.
For really old single core processor hardware, ( <= P4 ) you may need to use the Ubuntu 8.04 based distro
Anything else and you are largely on your own, either building from sources or sourcing and installing packages where they exist.
The following user(s) said Thank You: Jake
20 May 2015 21:06 #58897 by Jake
Thanks I will stick to what it proven as I need every bit of help I can get!
The machine that I have for the plasma table should run 10.04 as it was running Win7 X64 but it is an older machine I think its a dual core if I remember correctly
Jake
21 May 2015 05:34 #58910 by Jake
Ok looks like I am going to go with Debian Wheezy, I can not find an ISO to download from. The Debian site keeps kicking my to 8.0, There are other download sites from google but I am weary of downloading junk with them.
Thanks!
21 May 2015 06:34 #58911 by PCW
www.linuxcnc.org/index.php/english/download
and click on the "Download the ISO" link
21 May 2015 21:13 #58917 by Jake
It was the Linux distribution that I was having a challenge getting downloaded. I think I finally found the right files, between Debian and Ubuntu they want you to download the most current distribution so finding the older ones was a challenge.
I have both downloading now, it said 14 hours last night when I went to bed.....
21 May 2015 22:13 #58918 by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Which Linux distribution for new install?
The Debian Wheezy distribution is included on the LinuxCNC downloadable ISO.
21 May 2015 22:16 #58919 by ArcEye
I still have a nasty feeling you did not understand what PCW and I were telling you.
You need to go to THIS sites Home page and download the Live CD, which is either Ubuntu or Debian based.
Linuxcnc will not run on a normal install of either, you need the realtime kernel and modules that are bundled with the Live CD.
Hopefully I am wrong and you have not wasted your time :)
21 May 2015 22:20 #58920 by Jake
Im a retard....Thanks again guys. Yall never waste my time, I tend to waste a bunch of yours though! The learning curve of some of this is proving to be fairly steep.
That is way to easy to have it as one packaged component!
Time to create page: 0.179 seconds
