Intel D525MW - high jitter
10 Jun 2015 02:33 #59658 by TheChosenOne
Intel D525MW - high jitter was created by TheChosenOne
Hello, after reading posts about Intel D525MW I believe that buying this board was good idea:-)
However, in my case measured jitter is too high - base thread over 130 000 ns (2 glxgears running for 4 hours).
In BIOS I disabled Hyper-Threading and unnecessary devices (onboard LAN, audio). I also applied isolcpus setting but it didn't help much.
Please advice me how to tweak it.
Thank you,
Kamil
10 Jun 2015 18:59 #59670 by ArcEye
Replied by ArcEye on topic Intel D525MW - high jitter
The D525 has not been available for a couple of years with the big stockists.
What did you install on it?
All the testing will have been done with the Ubuntu 10.04 based distro.
You need to disable the power management, but so long since I looked, had to boot mine.
First page disable Hyperthreading
In the Boot menu disable system fan and set it to 100%. That gives max cooling (if there is a fan) without it needing to check the temperature. Adjust accordingly if you are in Arctic circle!
In Peripherals , disable Audio and Serial
Disable event logging
Use isolcpus=1 in the boot line
When I had the Ubuntu distro installed on it I tested it at about 10 - 12K, but I just use it as a media server and have standard Wheezy on it now.
Hopefully that might help, the big one is probably to try Ubuntu if that is not what you installed.
10 Jun 2015 19:06 - 10 Jun 2015 23:14 #59671 by ArcEye
PS
Forgot - in power management
Set ACPI to S1 and disable all the other suspend and wake options that you can
Last edit: 10 Jun 2015 23:14 by ArcEye.
12 Jun 2015 03:16 #59724 by TheChosenOne
Replied by TheChosenOne on topic Intel D525MW - high jitter
Thank you! I will check it on the weekend and will let you know about results
22 Jul 2015 22:05 #60826 by TheChosenOne
Today I finally got to install Ubuntu 10.04 on my D525MW and indeed results are better. After one hour of running 5 glxgears and browsing pdf file max jitter is about 20k. However I ran system monitor and noticed that both cpu cores are busy, although I edited /etc/default/grub and added isolcpus=1 parameter into GRUB_CMDLINE_LINUX_DEFAULT.
BIOS setting are set as you instructed. Is it normal behavior?
22 Jul 2015 22:08 #60827 by ArcEye
.... although I edited /etc/default/grub and added isolcpus=1 parameter into GRUB_CMDLINE_LINUX_DEFAULT.
Did you run update-grub afterwards and does it show up on the kernel boot line in GRUB?
22 Jul 2015 22:22 #60828 by TheChosenOne
I forgot about it, thank you. I just ran another latency test and will share results later.
24 Jul 2015 18:49 #60881 by TheChosenOne
After 16 hours of running multiple glxgears, system monitor and top command, maximum jitter equals ~ 32k. Is there another way of decreasing this value?
System is installed on a pendrive, can this is be a cause of problem?
24 Jul 2015 19:13 #60882 by ArcEye
It certainly won't help
Use the rtai latency test as outlined in my FAQ
www.linuxcnc.org/index.php/english/forum...-the-latency-problem
Then you will be able to see when the spikes occur
The other test is a cumulative one and gives no idea when a spike occurred or what the underlying figure is.
If you had one high spike on drive access through USB, it would continue showing that figure for ever more
24 Jul 2015 19:33 - 24 Jul 2015 19:35 #60883 by TheChosenOne
When tried to execute /usr/realtime-2.6.32-122-rtai/testsuite/user/latency/run I got an error rtai-load: cannot find run info: /home/jacoren/.runinfo
Last edit: 24 Jul 2015 19:35 by TheChosenOne.
Time to create page: 0.103 seconds
