Intel D525MW - high jitter
24 Jul 2015 19:54 #60884 by ArcEye
Replied by ArcEye on topic Intel D525MW - high jitter
Afraid I have not used Ubuntu for a couple of years and don't have it installed anywhere to try it.
I have never had a similar error to that though.
If navigating to the actual directory and executing ./run gets the same result, you may just have to use the graphical test, note when a spike occurs
and reset it.
Then try loading glxgears, seeing if the load of the first one creates the spike, moving windows to create graphics load etc etc
I would certainly recommend using a HDD. I have never run anything satisfactorily from a USB stick, not much different from running from CD to my mind
Time to create page: 0.050 seconds
