Cannot boot from ISO
- micro_marco
03 Jul 2015 01:31 - 03 Jul 2015 01:36 #60352
by micro_marco
Cannot boot from ISO was created by micro_marco
Hello,
I've downloaded the newer hybrid iso from this website, and used unetbootin to burn it to a usb stick, but it always fails to load to OS...I've tried it on 3 computers and i always get the same error....cannot start display: :0
any ideas?
any ideas?
Last edit: 03 Jul 2015 01:36 by micro_marco.
- ArcEye
- Thank you received: 758
03 Jul 2015 13:13 #60366
by ArcEye
Replied by ArcEye on topic Cannot boot from ISO
The error is an xserver one, but is a symptom rather than the actual problem.
Not all USB sticks are suitable for booting from and not all writing programs do it properly.
I have never bothered with USB and burn CDs or DVDs which boot without any issues.
If you have that option, use it. I long ago bought a USB connected DVD-RW drive to load onto any computers without their own ones.
If you don't have that option, can only suggest a fresh download and different stick.
Definitely do not use a Sandisk stick, it is very hard to clean the windoze s**t off them so that they will boot properly
The following user(s) said Thank You: micro_marco
- Thank you received: 3785
03 Jul 2015 18:14 #60377
Replied by rodw on topic Cannot boot from ISO
As a noob who has not even got any CNC hardware to control yet, I found that some PC's would boot from USB and others wouldn't. Most reliable was to burn to a DVD.
- Thank you received: 6933
04 Jul 2015 05:20 #60396
Replied by tommylight on topic Cannot boot from ISO
The debian version will work from an usb only if writen as an image directly with dd, i did not try norton ghost but it might work. With DD it works always, did it several times on several USB sticks and tested on several laptops and a dell optiplex xxx, all worked without a hitch.
Here is the link on how it should be done.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Hybrid_Iso
The unetbootin and ubuntu startup disk creator will not work, i did not try unetbootin but i know how it works so i assume it will not work, ubuntu startup i did test and it fails always.
Tom
Tom
- micro_marco
04 Jul 2015 07:47 #60401
by micro_marco
Replied by micro_marco on topic Cannot boot from ISO
Yeah...that was it!
Tried it with win32diskimager and it now booted in 2 out of my 3 computers! Just the one with nvidia card got a blank screen...likely a driver issue. the other 2 with AMD cards worked fine.
But to be honest i'm kinda disapointed with the performance of my litle Athlon 5350...i thought i had a winner here and got really bad results!
Time to create page: 0.219 seconds
