Mini ITX Motherboard
- Muzzer
- Thank you received: 37
24 Jul 2015 18:07 #60879
by Muzzer
Tiny Computer with Printer port was created by Muzzer
Looking at mini-ITX boards with PCI slot (for Mesa 5125).
Mini-ITX store
Sounds as if LCNC only uses one core and ideally I'd choose one with a single 12Vcd input. What minimum processor would I need to run 3-axis without impacting performance?
The recommended motherboard list seems to be mostly OOD now, so looks as if I need to look again. I'll be building this into the cabinet with my DMM Tech servo drives, PSU and probably a new VFD. I'm familiar with the need to avoid noise and interference due to the layout.
Murray
Mini-ITX store
Murray
- Muzzer
24 Jul 2015 22:08 #60886
by Muzzer
Replied by Muzzer on topic Tiny Computer with Printer port
They seem to do 12Vdc input Atom boards with PCI slot (for Mesa)
Jetway JNF9C-2600 Long Life Fanless 1.6GHz Atom Thin-ITX Board with 12V DC Input and CFAST for £99
My question is whether an Atom 1.6GHz is adequate. Couldn't see anything firm either way on the forum earlier today and a lot of the mobo info is now outdated.
Thx
Murray
Thx
Murray
- ArcEye
- Thank you received: 758
24 Jul 2015 22:19 - 24 Jul 2015 22:20 #60887
by ArcEye
Replied by ArcEye on topic Tiny Computer with Printer port
1.6GHz was good enough for the D525 Atom boards so don't imagine that is a problem
Latency is nothing to do with processor power. albeit it obviously does have an impact in other areas
The best bet seems to be a J1900 based board, search the forum for that and you will find several posts of the specific boards that PCW has tested
I think a couple of them are on the wiki too
If that is the 2600 Intel with GMA36xx video chip, then avoid itJetway JNF9C-2600
Last edit: 24 Jul 2015 22:20 by ArcEye.
- Thank you received: 4968
25 Jul 2015 01:11 #60893
Replied by andypugh on topic Tiny Computer with Printer port
I am reasonably happy with the Jetway I just bought:
www.mini-itx.com/store/?c=89#JNF9C-2800
There is a VGA header on the board, and a breakout cable is supplied if you need VGA.
It is low-profile so that a Mesa card can fit over the board on a short PCI riser for a nice compact installation. This works well with a 5i23 and I imaginewould be good with a 5i25 too.
12V DC input, as you requested. Not the cheapest board out there, but Linux installed without issue, unlike my terrible experience with a Gigabyte GA-J1800N-D2P which had an old, buggy BIOS.
(The Gigabyte might well be better with the latest BIOS, but the one I had couldn't even boot the BIOS updater and wasn't 12V DC input)
- Muzzer
25 Jul 2015 01:29 #60894
by Muzzer
Thanks Andy. Where did you buy it? Mini-ITX seems to be based in US.
Any views on using a touch screen monitor? I suspect it's one of those things that splits opinion but possibly avoids / reduces need for a keyboard, esp if coupled with a MPG pendant thingy.
Murray
Murray
25 Jul 2015 01:58 #60895
They are in the UK, but so am I.Thanks Andy. Where did you buy it? Mini-ITX seems to be based in US.
I am using it with a USB touch-screen monitor, it works as well as any other.Any views on using a touch screen monitor?
The following user(s) said Thank You: Muzzer
- Muzzer
25 Jul 2015 02:22 #60896
by Muzzer
Actually I'm now living back in the UK. Moved back from Canada last October. Hadn't noticed that my profile showed Canada but I've just corrected that.
What's the touch screen monitor you've got - could you share details? The monitor doesn't need to be fancy resolution or fast but a new 15-17" touchscreen monitor is best part of £150 - 200.
- SrLange61
- Thank you received: 5
29 Jul 2015 04:02 - 31 Jul 2015 07:32 #61005
by SrLange61
Replied by SrLange61 on topic Tiny Computer with Printer port
I just found this review of the new ASRock MB's.
www.eteknix.com/asrock-n3150-braswell-motherboard-round-review/
I'm tempted to get the N3150B-ITX as its available here in Sydney Aust.
srl
srl
Last edit: 31 Jul 2015 07:32 by SrLange61.
- Muzzer
29 Jul 2015 17:23 #61013
by Muzzer
Looks like a nice little MB. Couple of questions / issues, depending on what it's used for:
- Lacks a full PCI slot (if you plan to use a Mesa 5i25 card, that's a problem).
- Needs an ATX 24 pin power supply. I'd prefer just a single 12V supply myself.
- Can LinuxCNC use more than one core?
Time to create page: 0.078 seconds
