Reseting the root password in Linux?
- Adoug
13 Aug 2015 09:31 - 16 Aug 2015 22:15 #61367
by Adoug
Reseting the root password in Linux? was created by Adoug
Holding escape, nor any of the f keys or anything apparently does not get me the grub boot prompt. I need to send a file over the parallel port using the cat command.
Last edit: 16 Aug 2015 22:15 by BigJohnT. Reason: the subject was misleading
- ArcEye
- Thank you received: 758
13 Aug 2015 14:50 #61374
by ArcEye
If you can do it as root, you can do it as sudo
Run man sudo in a terminal or google it.
Depends entirely upon what version of GRUB, what BIOS version etc.
We have no way of guessing what you installed and onto what.
If you have a USB keyboard, on older machines you cannot do anything with it until the USB drivers are loaded, not even select a boot option in GRUB
Replied by ArcEye on topic Reseting the root password in emc2?
- Adoug
16 Aug 2015 10:28 #61422
by Adoug
Replied by Adoug on topic Reseting the root password in emc2?
Apparently there is some kind of rare exception for printing system, you need to actually give the root password. I tried sudo, and it asks me for the root password.
I was never able to find out the default root pw for emc2, I googled a lot. It used to not be set by default or something?
It is ubuntu version 10.04 lts. I really need to fix this, can anyone help?
- ArcEye
16 Aug 2015 13:12 #61424
by ArcEye
Have you tried just putting in your own password?
The whole point of sudo is that it prevents lots of different people knowing the root password, so it is not going to ask you for it, you should not know it.
- ArcEye
16 Aug 2015 20:02 #61437
by ArcEye
If you tell us exactly what commands you are using etc. may be able to assist more.
In addition to the issues in this link
ubuntuforums.org/showthread.php?t=2060188
there is the little matter of parport driver blacklisting ( or redirecting to null ) in distros, to prevent parport_pc etc grabbing it before linuxcnc
and preventing linuxcnc from working.
- Adoug
17 Aug 2015 10:02 #61478
by Adoug
Replied by Adoug on topic Reseting the root password in Linux?
Heya? Otherwise I need to get a cd image written and re-install everything, I guess.
Time to create page: 0.155 seconds
