2015/2016 Hardware that works...
10 years 8 months ago #69701 by PCW
If you have the H97 MB it looks like the NIC is not supported by wheezy, but tperry in this thread was able to get the driver updated and working.
forums.debian.net/viewtopic.php?t=112327
May help
Another option is to use Preempt-RT/LinuxCNC uspace and a more recent kernel
(4.4.1-rt5 is the latest )
10 years 8 months ago #69705 by tperry
Check my other post for a link to the drivers. If you need help compiling them let me know and I'll post more detailed instructions.
Tim
10 years 8 months ago - 10 years 8 months ago #69706 by kiaw
Thanks for replying.
Yes, I downloaded the driver and attempted to compile it. During the make it stopped with an error saying something like e1000.7 couldn't be accessed. So, I was unable to get the network running.
I did install the preempt RT. [strike]This did provide networking, but latency jumped from about 4000ns base up 28000ns. So, if I can get the live install running, it would be better performance.[/strike]
i've gone through the bios and disabled everything that I could. Now latency is about 6000ns, so this is a lot better. So I plan to stay with the preempt kernel instead of the live install.
Thanks,
Pete.
Last edit: 10 years 8 months ago by kiaw. Reason: fixed problem
10 years 8 months ago #69882 by tperry
I downloaded the e1000e-3.2.4.2.tar.gz ( I am making it available at www.dropbox.com/s/h5ij1zmt1udawgq/e1000e-3.2.4.2.tar.gz?dl=0 ) if you want to use the same one I did. One thing I noted is I had to reboot after the install.
tar zxvf e1000e-3.2.4.2.tar.gz
cd e1000e-3.2.4.2/
cd src
make
make install
reboot
After reboot do an
lsmod |grep e1000
and see if the modules is loaded. if so you should be able to do an ifconfig and see there is an eth0 now available. Configure the network as you normally do.
Let me know if that doesn't work.
Tim
10 years 8 months ago #70402 by kiaw
I had to get some parts made, so I only got to try your procedure today. The driver loaded and I have networking working..
I think this will be a better kernel for software step generation.
Thanks,
Pete.
10 years 7 months ago #71129 by gzcwnk
I am using a vonets Var11n-300 to connect to my wifi, (though I think the VAp11n is waht I should have bought, about $16USD) Anyway it needs a laptop with wifi to get it into repeater mode and then you plug its ethernet cable into the onboard NIC and you have internet!
Time to create page: 0.342 seconds
