So I went with PCW's recomendation and put in aASRock H97 Pro4 with an Intel G3258 CPU, 8GB Memory ( perhaps one day I will run 64bit ).
Additionally I put in 2 StarTech PCIE parallel ports and an Intel PCI Wireless N RNX-N250PC2 card.
Initial performance was dismal. Over 1 second delays, so I started pulling out hardware that was not essential, the network card. Immediately I am getting stable Max jitter of 3602 Servo & 4012 on the Base. So I really wanted this on the network so I threw on a bridge I have to the onboard network port ( after downloading and compiling the driver from intel as the Wheezy drivers did not work (
downloadcenter.intel.com/product/71305/I...et-Connection-I218-V
) and viola still stable within 10-30ns of the pervious test. I found another alternative to removing the Wireless networkcard is just to disable wireless networking in the network control panel and everything will be stable, so you could use it that way, just when running linuxcnc be sure to disable Wireless networking.
This result is with glxgears running, about 85-90% CPU usage, surfing the internet, and downloading over 1GB of data during the test. Pretty good results.
So I feel like I know have a system that is capable of driving my Mill.
Thanks all for the suggestions.
Tim
