Touch Screen Recommendations
9 years 9 months ago #85074 by perra_e
I gave up on my ELO and bought an ASUS VT207N that works for people here.
Just got it and of course it doesn't work for me :-(
I found out it works with RTAI, but I have to use RT kernal, and under RT it dosn't work.
It seems that I shall not have a touch screen :-( :-( :-(
I have searched a bit on Google but I can not find anything.
Has anyone else get this screen to work under RT?
9 years 9 months ago #85075 by cncnoob1979
I have it working under Preempt RT.
What OS are you on? Did you issue modprobe as stated above?
9 years 9 months ago #85077 by perra_e
Oh, that sounds promising!
I issued modprobe, and it works with RTAI kernal, but not RT.
I use latest iso from linuxcnc download with all updates. uname - v = SMP PREEMPT RT Debian 3.2.84-1
Are you using an other OS?
9 years 9 months ago #85082 by perra_e
I started to look at Linux Mint and found out that you are using that.
I will give Mint 17.3 a try.
Posting result here after I tried it.
--Per
9 years 9 months ago - 9 years 9 months ago #85166 by perra_e
After some trouble I managed to install Linux Mint, Preemtive RT and compile linuxcnc. Touch screen works fine, but it is always a new problem. Now the latency is sky-high. On Debian with preempt it was around 20 000 if I remember correct, now it is almost 8 000 000. I have tried to turn off 3 out of 4 cores with "echo 0 > /sys/devices/system/cpu/cpu1/online", but no difference. I have no idea where to look to improve this now :(
uname -a = Linux FS3MG 4.1.5-rt5 #3 SMP PREEMPT RT Tue Jan 3 18:25:07 CET 2017 x86_64 x86_64 x86_64 GNU/Linux
I'm using a Asrock Q1900DC-ITX mother board.
Any one having any idea???
edit:
Thought it might be memory, but it looks ok.
MemTotal: 3747500 kB
MemFree: 1942444 kB
MemAvailable: 2683328 kB
Last edit: 9 years 9 months ago by perra_e.
9 years 9 months ago #85182 by rodw
Replied by rodw on topic Touch Screen Recommendations
Disabling the power saving stuff in the bios can help. I've seen similar latency when using the on board wifi on a J1900 PC. Replace it with a USB wifi dongle.
Time to create page: 0.338 seconds
